evo IV flickering/tickering noise :(
Old Jul 27, 2012 | 07:46 PM
makulitz's Avatar
hey guys.. i just have a quick question.. i noticed my car has making this weird flickering/tickering noise on idle after applying gas.. its sounded like "tttrrrrrrrrr" that's the closest sound i can describe it off.. lolz! i've got some video clip of cold start and this weird noise.. hope u guys can help me figure out what this sound is.. thanks!
cold start
flickering/tickering noise : i just used my ipod so just bare with the crappy sound, you'll notice this weird sound right after letting go of the gas.. you can hear a bit clear around 0.20s up
__________________
Old Jul 27, 2012 | 08:45 PM
novem's Avatar
You can try using a piece of tube, and point it at different places to narrow it down ( like a stethoscope ). It's a old mechanics trick. You might try checking the bolts on your exhaust manifold, 02 housing, turbo..if a bolt is loose, or missing it can make you engine noisy and it doesn't take much gap. The other thing would be to do a oil change and add a quart of Lucas oil stabilizer. That stuff works pretty good for lifter tick on 4G63s. Anyway the hose thing should help you narrow it down!
N
Old Jul 27, 2012 | 09:12 PM
makulitz's Avatar
oh i just did an oil change and havent drove this car yet since.. would that lucas oil stabilizer help this tick specially in cold start? its just kinda annoying when you hear it on the start up.. i'll check those bolts you've said.. btw, do u know how much ft/lbs of torque for the valve cover? cause i checked it before and bolts are like finger tight.. and i had to tight just a bit tud. thanks btw.
Old Jul 27, 2012 | 10:09 PM
novem's Avatar
96 eclipse gsx 4g63 valve cover TQ is 24 inch lbs., 2003 Evo valve cover tq is 31 inch lbs. The 03 was the first year they made the valve cover out of magnesium..so I would go finger tight and see what a 1/2 turn looks like on your torque wrench and go by feel, or maybe hit up the UK Evo website.
On the oil, you can drop a quart out of the pan and add the Lucas. I had 4
DSMs before the Evo, and it did get rid of the tick noise all together. After you pour it in wait a few minutes before you crank it over..it's thick as maple syrup!
Good luck!
N
Old Jul 27, 2012 | 10:15 PM
makulitz's Avatar
got another question again, does all 4g63t oem oil pressure sending unit would work in IV? i've found mine leaking a quite a bit..
Old Jul 27, 2012 | 11:02 PM
novem's Avatar
http://www.lancerregister.com/index.php
Lancer reg. Will have more info on 1-7 Evos, and the have manuals for them also.
N
