knock on cold start
Old Jul 29, 2012 | 10:25 AM
deadstockkpomp's Avatar
knock on cold start
im getting this knocking sound on cold starts like only if i let the car sit overnight. i think it just started happening after i havent drove my car for about a week, tephra mod is not picking it up no ses flashing and it goes away once i drive and you never hear it again? if i rev the motor i dont really hear it either. car has cams and some other mods. and im pretty sure its not the clutch, engine oil is full. i posted this in the drivetrain section but it wasent getting attention sorry im really looking for suggestions. This car is so random i dont get it sometimes, i dont even beat on it.
http://i878.photobucket.com/albums/a...p/f379047b.mp4
Old Jul 29, 2012 | 11:06 AM
knx240's Avatar
Link does not work!
Old Jul 29, 2012 | 11:21 AM
Links updated, car only does this after being off for hours once its warmed up it sounds healthy and runs great i just dont get it
Old Jul 29, 2012 | 12:36 PM
bumpppppp
Old Jul 29, 2012 | 12:43 PM
rick1024's Avatar
i had this issue with my k24 in my rsx. a buddy of mine who is hardcore mustang said that its normal and to not run it hard when its cold. let it warm up a good bit before giving it any throttle
Old Jul 29, 2012 | 12:46 PM
i let it warm up for at least 5 before moving the car it just started randomly im scared i dont have money to do a motor rebuild. can it be a pulley or something. maybe piston slap?
Old Jul 29, 2012 | 02:34 PM
Bumpppp
Old Jul 29, 2012 | 02:58 PM
mblaster890's Avatar
It's usually piston slap. It happens on motors that are on the "loose" side. I've had a few dsm's do it as well as my current Evo does it ever soo slightly now and then. Unless it's really bad, I wouldn't really worry about it. My last stroker motor did it from day 1 and that car saw 35+ psi from an HX 40 on a daily basis. When torn down it looked fresh as could be.
Old Jul 29, 2012 | 03:07 PM
Happens when car settles to 14.9 afr but temp is still very low, once i drive around the motor sounds 100%. Would you consider this Normal? it freaked me out because it just started happening
Old Jul 29, 2012 | 06:13 PM
So when you start the car from a cold start, how long does it go on for? Mine is only briefly, say 1-2 sec.
If it goes on much longer then that, and slowly fades with rising engine temp, it VERY well could be a rod knock. I've seen high mileage cars knock like hell on cold starts (think ball peen hammer on a piece of steel), and go dead silent after 2-3 mins of running. When you change your oil next, look for ANY colored shiny stuff in it. Ie: make sure it's a nice clean pan, and check it in the sun after you drain it. If anything is there you will see it glint in the light.
Old Jul 29, 2012 | 06:34 PM
Oil was changed less then 1000 miles ago, And my knock sensor isent picking it up. It last for a little ill try again tonight
Old Jul 29, 2012 | 10:14 PM
its still making the noise but i really dont think it could be anything that bad its not that loud i mean you can hear it and it goes away as soon as you start driving so i dont know. the knock sensors not flashing i give throttle it does not speed up.
http://i878.photobucket.com/albums/a...p/e9ee0476.mp4
Old Jul 30, 2012 | 07:10 AM
bumppppppppp
Old Jul 30, 2012 | 08:37 AM
Sound may be coming from the cam gears i put my ear up to it and its loud there, and i started the car today and it wasent that bad today after giving it a good drive last night lol
Old Jul 31, 2012 | 05:22 AM
Are you sure it's not just lifter tick then? Or a noisy rocker? Both are pretty common. Without hearing it, it's literally just a guessing game bud.
