Inner CV axle broken bearing?
Old Jul 30, 2012 | 12:41 PM
pignosesr's Avatar
Common problem? It had a violent wobble on the side of this axle. Figured id replace the whole shaft till i heard something clanking inside the inner cv boot. Curious to what it was I took off the boot (BOOT IN PERFECT CONDITION) and sure enough one of the bearings was off. I found all these little parts around in the boot.
My question is, is this common? Seen alot? Is it possible to just replace the triangle bearing assembly thing, put everything back together and use it? Or should i just replace the whole thing.
