slight clicking noise from front driver after axle change
Old Jul 30, 2012 | 05:00 PM
KJS's Avatar
KJS
So I had an axle changed and when I was driving home I heard a fairly faint clicking or ticking noise that changed in frequency as the cars speed changed.
Any ideas what could cause this? Wheel bearing, some dirt in the axle joint? I didn't check for a rock in the tread but its always possible cause the shops lot is all gravel
Old Jul 31, 2012 | 04:37 PM
sternevo8's Avatar
I have the same issue man....just finished a clutch job and both axles were removed and reinstalled. Its coming from both sides. Im going to make sure its not my brakes...I didnt touch those so I dont know if thats the issue or not...Its a scratching sound as i drive, its very noticable in tunnels and parking garages. Its not the splash shields behind the rotors, I just put brand new ones on....let me know if you figure it out and ill do the same...im rebuilding my calipers now so it might be a little while
Old Jul 31, 2012 | 04:38 PM
KJS's Avatar
KJS
I think mine just went away, i drove to work today and didn't notice it at all. Ill listen a bit closer and keep you updated
Old Jul 31, 2012 | 05:54 PM
GTijoejoe's Avatar
It was the axle cups breaking in... its normal dude... doesn't always happens.. but sometimes.
