AEM UEGO help
Old Aug 4, 2012 | 03:08 PM
apiazza2010's Avatar
AEM UEGO help
I installed my wideband and now I am trying to log it with Evoscan.
I solder pin 2 to the blue cable and pin 5 to ground of a serial cable to usb adapter. Installed drivers for the adapter and using COM5.
I checked for voltage on the cable and I get around 2.23 fluctuating when the wideband is on.
Now in evoscan I select AEM UEGO 9600 and i select my com port.
I ticked the WDB on the log options but all I get is 0 value.
I redid the soldering 3 times now thinking the cable was faulty but now I really dont know what to do....
Thanks for any advice
Old Aug 4, 2012 | 03:12 PM
evokid511's Avatar
you have the "external wideband" check in evoscan?
Old Aug 4, 2012 | 03:16 PM
yes, the "reading" column just shows a 0 when I start logging with the wideband on
Old Aug 4, 2012 | 03:36 PM
is there any way to test the serial to usb adapter? I have windows 7, it seems that i'm not getting anything through while the adapter seems to be installed correctly.
