Compression test result .. Need advice
Old Aug 6, 2012 | 09:05 AM
fel222's Avatar
Hi there
Ive found a evo 8 that might interest me,
I did a compression test on it,
I had
1- 165
2- 145..
3- 165
4- 165
Should i worry? Or not buy it at all.. Its the only thing ive found on the car..
Old Aug 6, 2012 | 09:10 AM
Anarchy99's Avatar
Sounds fine to me, add more boost
Old Aug 6, 2012 | 09:12 AM
fel222's Avatar
The car doesnt burn oil at all, but it seems a hudge 20 psi difference ,
Old Aug 6, 2012 | 10:00 AM
fel222's Avatar
Any more input on this ?
Also the sunroof does not tilt or open, but i heard the motor working fine,
Old Aug 6, 2012 | 11:03 AM
acidtonic's Avatar
Obviously something in #2 is off.....
I'm not an expert with compression numbers but normally you want them all to be similar.
It's how similar they are more than the peak number in my opinion.
Old Aug 6, 2012 | 11:16 AM
Boosted Tuning's Avatar
First off, was the car warmed up during this test? also, did you test each cylinder twice? I test each cylinder twice, so I can make sure the numbers are accurate.
Next, that #2 cylinder has something up, if the numbers are correct. You may wanna try putting a lil oil into that cylinder and retesting. If the compression goes up after putting oil in the cylinder, then the issue is the rings. If it stays the same, then move on to a leak down test to find your issue.
Last, the spec for difference in cylinders is 14psi.
Old Aug 6, 2012 | 11:28 AM
fel222's Avatar
Thanks for the responce,
I tested number 2 three time just to be sure, i have a good gage ( mac tool ) also so the problem is not here,
The car was warmed right, i did the compression test right after the roadtest,
If it would be piston ring, how long the car can still run like that,
If its the valve, how long can it run like that?
Thanks
Old Aug 6, 2012 | 12:45 PM
fel222's Avatar
Upp
I guess the guy is just trying to rip off a noob kid, you should have seen his face when i showed him my gage haha..
Old Aug 6, 2012 | 03:24 PM
ExViTermini's Avatar
I've had a piece of carbon stick on a valve and give some messed up results on both compression and leakdown, mind you this was on 911 aircooled, but it's still an engine. I'd run the engine again, and retest it.
Old Aug 6, 2012 | 05:20 PM
fel222's Avatar
Tomorow it will go to a leak down test, so will have some good or bad new tomorow....
Old Aug 6, 2012 | 09:30 PM
fel222's Avatar
No one want to share his experiance?
Old Aug 7, 2012 | 03:46 AM
xxthayxx's Avatar
it's probably a valve. I had the exact same compression numbers as you but cylinder two got worse as the months went by(from 145 to 135). did a leakdown test and found that i was losing compression from the intake valve.
Old Aug 7, 2012 | 05:51 AM
GTijoejoe's Avatar
I'd lean in this direction too...
... and I don't think someone is trying to 'rip you off'... it happens dude, as you even stated, you can't even tell.
Old Aug 7, 2012 | 08:02 AM
fel222's Avatar
With a valve job to do on the car, it doesnt worth anymore 20 000 i guess
Old Aug 7, 2012 | 12:09 PM
barneyb's Avatar
Unless this was a garage queen, this is getting to be an old car. The only thing that surprises me about the compression readings are the three cylinders.
