worst dyno day ever
Old Aug 14, 2012 | 07:44 AM
  #61
deadstockkpomp's Avatar
Originally Posted by Chef-j
Hey good for you enjoy!
im keeping my fingers crossed still until it goes on the dyno again lol
Old Aug 14, 2012 | 08:38 AM
  #62
ToddRhodes's Avatar
How exactly does an EVO go off-time for base timing, aren't they like 2Gb DSMs where they do that themselves?
  #63
ToddRhodes's Avatar
Edit - I suppose it could be a mechanical thing...
Old Aug 14, 2012 | 10:41 AM
  #64
now theres a problem with the cams clearing on the exhaust side. now the head needs to be sent out and checked
Old Aug 14, 2012 | 11:15 AM
  #65
fastyouth1313's Avatar
What do mean by they Arnt clearing?
Old Aug 14, 2012 | 11:23 AM
  #66
apparently the cam on the exhaust side will not turn all the way with the timing set correctly. so it can be a possible bent valve or the head needs to be re-cut or replaced
Old Aug 14, 2012 | 11:53 AM
  #67
ToddRhodes's Avatar
Welp, that just got awkward in a hurry... that would definitely explain some things though.
Old Aug 14, 2012 | 12:02 PM
  #68
Good god man! That sucks!
Old Aug 14, 2012 | 12:04 PM
  #69
SmurfZilla's Avatar
previous owner of the car? Maybe they set the timing that way to hide the damage?
Old Aug 14, 2012 | 12:09 PM
  #70
needsboost's Avatar
Sounds like it smurf, at least you found that big of a problem before it got way worse. Thats a big douche move to try and cover something like that up that way.
Old Aug 14, 2012 | 12:32 PM
  #71
ToddRhodes's Avatar
Agreed, I'd be livid if I found that... thankfully I just did my tbelt and all was good but damn...
Old Aug 14, 2012 | 12:38 PM
  #72
DsmGuy86's Avatar
Hey man sorry to hear but hey at least your car is in good hands sounds like the shop its at is doing a good job well good luck man hope everything works out soon and trust me it will be so worth it in the end
Old Aug 14, 2012 | 04:06 PM
  #73
AkumaMotorsport's Avatar
We will get some pics up tomorrow. WHat we found was really surprising. IO am not even sure how the car was driving at all.
The cams were off by a 1/4 TURN...probably 10 or more teeth...crazy. So if the timing notches in the gears are supposed to be at 12 o'clock(lining up with the V Cover notches)..they were actually at 3 and 9 o'clock. There were actually marks added to the gears to get it in some sort of time....wrong time.
The exhaust cam actually seems to cause the valves to hit the piston at TDC. I will get pics up and then give a more detailed idea of what the cause was. We are pulling the head to see what is actually going on. It is possible the head was cut too far and is too short....the valve job may be completely terrible....or the cams could be for a different application. There are other possibilities, but you get the idea. So I will follow up tomorrow with more info.
I feel bad for the customer, because if the head was cut too much, we have to replace it. At the very least, he is looking at a valve job...a couple new valves...decking...cleaning, etc. I am hoping the combustion chambers and pistons look good. Lets keep our fingers crossed.
Thanks guys.
John
Old Aug 14, 2012 | 04:45 PM
  #74
turbotalawd's Avatar
So if its possible the valves are bent, how come it showed good compression numbers? Also, if the valves were hitting the pistons at TDC, how come there was no tapping noise heard from the motor while it was operating?
Old Aug 14, 2012 | 05:40 PM
  #75
Chef-j's Avatar
+1 i'm also wondering that.
Plus, if timing was that off... Isn't easily see something wrong during the dyno? beside just not making enough power
Edit: Btw op, sorry to hear what is happening to your car.
