would like a refresh! input please
Old Aug 10, 2012 | 08:38 AM
spadednick88's Avatar
Whats up guys just a quick question so im currently running a 2.4 stroker n in a couple months when its winter im pulling the motor to paint my bay n while its out i would like to freshen up my block. What should all be done? It has all manley internals right now do i just change rings, bearing etc? As long as there is no problems thanks for any input
Old Aug 10, 2012 | 08:51 AM
selp's Avatar
How long has it been since you did the 2.4?
If you havent changed the pumps, ill say that could be a good thing. Replace belts, replace vacuum hoses, typical maintenance that is easier with the motor out.
Old Aug 10, 2012 | 09:07 AM
The motor has less then 5k on it
Old Aug 10, 2012 | 01:57 PM
jake-e-boy's Avatar
as long as it was built to spec it should be good for at least 40,xxx miles with basic maintenance
Old Aug 10, 2012 | 07:54 PM
Ya well it uses a little oil and while its out i would like to tighten it up i dont wanna pull the motor and put it back in n spin a bearing or some **** and end up pulling it again and i dont see my motor lasting 40k miles at 600 whp maybe thatd be nice lol
