motor mounts DD
Avid Mounts and Energy Poly Bushings in the front/rear suspension over here.
Oh, did I mention no balance shafts and some woppita woppita, too?
Women pay me for rides.
i just ordered my front MM from torque solutions. any other parts you guys recommend that will compliment it besides the other mounts.. such as rear diff bushings / torque damper ?
does anyone know first hand if the front MM will vibrate more/less than if it was run with the two side ones as well ??
my torque solution front MM just arrived today, and im going to install it tomorrow.
which one did you replace? just the front one ?
i was just curious if doing the side oens (cam gear/tranny) along with the front will increase or decrease vibs?? many posts say the more the worse, but some people have stated it cancels each other out and actually runs smoother than the front alone :S ??
I will be installing the black AMS front motor mount bushing and the black Energy suspension Rear Diff/Mustache bar kit in a couple of weeks, I will report back with the immediate results. I'm curious how it will turn out, I had some pretty stiff mounts in my MS3 and the vibes weren't really the problem, it was the extra noise from the drivetrain.
