**** perrin psrs ****** mod
Old Nov 23, 2012 | 07:53 PM
Grimgrak's Avatar
Can op rehost pics of rubbing please?
Old Mar 9, 2014 | 08:04 AM
heel2toe's Avatar
Bump- I too would love to see the pictures where clearancing is needed.
Also what did people use as a dye to press out the old bushing? The closest one in the ball joint service kits are 3" and the bushing is just a hair smaller so I would like to find something better so I won't be forced to press out the dye after I remove the bushing.
I was thinking exhaust tubing maybe?
Old Mar 9, 2014 | 11:13 AM
foxbear2277's Avatar
I used a hydraulic press with BMW bushing sockets Fit like a charm
Here are the spots that need clearance. Note that it is easy to oversee this issue as when the suspension is unsprung and wheels are off the ground there is lots of clearance. However if you do not add clearance you will have an awful clunking noise every-time it makes contact
https://fbcdn-sphotos-d-a.akamaihd.n...38628865_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...60389288_n.jpg
Old Mar 9, 2014 | 02:12 PM
heel2toe's Avatar
Thanks for the pictures now I can really see it.
Was that all done with an air hammer or just by swinging a hammer?
As to the bmw sockets can you comment on where you sourced then and and if it was such a tight fit that you had to then press it out of the lca.
Im having a hard time finding a suitable dye that isnt such a tight fit...
Thanks
Old Apr 2, 2014 | 12:21 PM
aggieEVO's Avatar
Did anyone every say if an air hammer was best or if I just need to use my manly strength?
JDavenport
Jul 6, 2018 11:26 AM
Roen
Jun 26, 2016 07:09 AM
MRLancer05
20
Jul 5, 2015 10:02 PM
darkknightsw20
May 15, 2015 12:13 PM
fjm9898
12
Apr 23, 2015 01:36 PM
