Bleed screw on brembo snapped off inside
Old Aug 20, 2012 | 01:38 PM
marcusE's Avatar
Well started to remove my bleeder screws to send the calipers out for powdercoating today and as always one of them was stubborn.
Ended up snapping it off flush with the caliper and didn't get to drain completely.
Will I run into any problems when I go to put them back on the car and fill up the fluid since I can't bleed one side? Its the inner bleed screw on the on one of the front brembos and one of the rear brembos.
Old Aug 20, 2012 | 04:11 PM
sternevo8's Avatar
I would suggest getting them to a machinist to have them drilled out or else you will not be able to bleed them properly....you need to hit all the bleeders to asure you are not leaving any air in the system.
