Mounting options in your evo
Old Feb 3, 2004 | 02:07 PM
RenoEvo's Avatar
Question Mounting options in your evo
I was just curious to see where you guys are mounting your SAFC's/ turbo timers/boost controller. Im installing my stuff in a couple of weeks and just wanted some ideas.
thanx
Old Feb 3, 2004 | 02:16 PM
rocketscience's Avatar
here's my turbo timer. I changed it a bit since the install. In the pic you can see the wire running over the unit. Taped with electrical tape. I replaced the velcro with Superlock. Much stiffer and stronger. Same stuff we use in IL for our IPASS. But I made 4 small patches and basically created a 'groove' where the wire can run. So the wire now sits behind the turbo timer display and you hardly see it.
Old Feb 3, 2004 | 02:36 PM
BlueByYou's Avatar
Where did you get the superlock at? A place like home depot? I didnt really look that hard for it i just checked walgreens and the like.
Old Feb 3, 2004 | 02:57 PM
ruthless evo 8's Avatar
Yes i would be interesting in knowing where you got the superlock at too.
Old Feb 4, 2004 | 04:57 PM
jsprat7's Avatar
i got my tt mounted to the top of my 'cubby hole' and my bc mounted underneath the 'cubby hole', right above the ashtray. there is still room to open it and take it out. i also have my bg mounted to the top of the steering column.
Old Feb 4, 2004 | 10:47 PM
Deceit's Avatar
I built a little CF "enclosure" for my turbo timer in the 'cubby hole' under the radio and another little enclosure for my HKS EVC control box where the ashtray was. It was just simple cutting with a dremel. I'll take some pics tomorrow.
