Limited slip diff question
Old Sep 23, 2012 | 10:36 AM
EvolutionIX219's Avatar
Couldnt get a straight answer from other post and manual does specify. Would 75w140 valvoline LSD work? If so you just need one quart for rear axle right? Thanks
Old Sep 23, 2012 | 01:08 PM
barneyb's Avatar
A straight answer would be that I have used this product and it does or does not work fine. I haven't.
The SM says 80W-90, 85W-90 or SAE 90 GL-5 hypoid gear oil. Then there is the LSD component, the additive that keeps the clutches from chattering; it may or may not work with the differential in you car.
The rear differential capacity is 0.58 quarts.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
