What your best 1/4 mile tims In a 6spd
I'm putting down 500hp 400ft. With percision 6265 on stock bottom end and stock 6sp. The reason I'm doing it with a 6sp is I wanna see how far I can push it why not its in there and it works fine. I only ran it 2.5 times before my clutch was completely done for. I went 12.2 @122, 12.3@121, and 12.8@88. My clutch was so bad after the runs that I could put it in 1st let the clutch pit with the ebrake up and it wouldn't stall out. Putting a twin in as we speak. But while it's down I went with a cop setup and ams intake manifold, gonna put some race gas in it and a tune and see if I can get low 10's or maybe a 9 with stock bottom end and 6sp just for the fun of it. Run what you got. Btw the reason for the 12's at such a high speed was the act lockout in second at high rpms and having a bad clutch
11.48 @ 121...I have trapped 123mph though.
This was on stock block, S2s, BBK-B turbo, 93 oct. Tune was pretty mild & at 27psi.
Hankook street tires, didn't touch psi. ACT unsprung 6 puck clutch & fidanza flywheel.
Race weight around 3300 with me in the car & 1/4 tank of gas.
A more aggressive tune & around 30psi or so I wouldn't have a problem seeing low 11s, but I had to shift to 5th at the 1000ft marker & my 6 spd already hates me, haha...
^^^The difference in tire size with the QTPs is what helped him trap 131mph @ only 8300 rpms in 4th gear with the 6 spd.
For example, I run 255/40/17 street tires, I am lucky to get 120mph by around 8200 in 4th gear with the 6 spd.
I pulled a 1.56 on that run
I'll post a link to my thread, I've got a video of the run.
Exactly, the QTP's are much taller tires so I'm about to get more mph out of each gear.
