Evo running rough when cold
Old Oct 13, 2012 | 06:31 PM
Brent_si's Avatar
Friends evo is running rough but only when the motor is cold. The widebad reads very lean and it will die if it doesn't have throttle. This started happening right after he washed it with a pressure washer. Some water was sitting down in the valve cover for a few min. It is not throwing any codes. Any ideas what it could be?
Old Oct 13, 2012 | 07:45 PM
kamakazy_kid's Avatar
You might have water in the fuel tank, I had the same issue occur after pressure cleaning the engine bay.
I bought some water evaporator that you add into the fuel tank and it gets rid of any water that could be in there. Give it a try and see if that works for you.
Old Oct 13, 2012 | 10:26 PM
dkslvr06evo's Avatar
try some "Heet" in the tank
Old Oct 14, 2012 | 02:11 PM
Brent_si's Avatar
I will tell him to give it a try.
Old Oct 15, 2012 | 05:37 PM
Brent_si's Avatar
Drained the tank. back to normal...
Old Oct 15, 2012 | 05:43 PM
evo7vii's Avatar
so draining the tank solved the start up issue?? i am having almost the same thing when cold with the lean AFRs and it takes time till it adjust and start running normal.....
Old Oct 16, 2012 | 03:46 PM
Brent_si's Avatar
yea it must have had a little water in the tank. It runs just fine now. I didn't think it was safe to let it run like that so i gave it some throttle. This was at like 18.2:1 and it may have been lower as that is as far as this wideband goes.
Smithta
Oct 1, 2015 03:41 PM
nsheasley
Jun 3, 2015 08:44 AM
JTCB
May 31, 2014 07:22 AM
moss99
Feb 19, 2011 07:47 AM
melon07
27
Nov 6, 2008 01:12 AM
