Vacuum Lines???
Old Nov 2, 2012 | 04:18 PM
projektevo9's Avatar
Vacuum Lines???
Anyone happen to know are most of the vacuum lines on an 06 ix the same size all of the smaller line Ian it 2x3mm if you were to replace most of the line would you think 30' would be sufficient if anyone knows the size of the majority of the hose I would appreciate the input thanks guys
Old Nov 5, 2012 | 12:29 AM
Bump anyone know
Old Nov 6, 2012 | 09:34 AM
deukalions14's Avatar
Just take a sample of each line, figure out how much of each you need, and take it to a napa or something and pick up the length and size you need. I recommend taking your time and getting extra length and save the wasted trips. Don't forget the rubber caps and maybe replace the T-connectors while you're at it.
Old Nov 6, 2012 | 10:21 AM
Macaroni's Avatar
Holy run-on sentence man...
Just do what deukalions14 said and get a sample of everything. There are different sized lines so it would be best to cut off a small section and take it with you to the parts store. And write down the length of each line so you know how much you will need. Then add another 6" to the total length just for good measure.
Old Nov 6, 2012 | 01:18 PM
evodriver49's Avatar
alot of the vacuum lines are 5/32" (boost gauge, wastegate, compressor turbo line, etc)..
Old Nov 6, 2012 | 02:02 PM
That's what I needed to know thank you
evoxbrampton
Apr 29, 2014 05:48 PM
Ralli04Art
15
Apr 17, 2013 09:37 AM
blazersman
Jul 19, 2011 08:28 AM
Babs
Nov 3, 2009 01:13 PM
8ASTI
Dec 29, 2007 11:49 AM
