Bov position
Old Nov 10, 2012 | 01:38 PM
89Saleen141's Avatar
Bov position
What is the difference between running the bov on the intake piping or the uicp.
Old Nov 10, 2012 | 02:00 PM
code4evo's Avatar
Im not sure if im right but the one on the intake is recirculated. the one on the UCIP is 100% atmospheric. I just put in a HKS one and it sound great.
Old Nov 10, 2012 | 02:15 PM
YogSaahoth's Avatar
Veteran: Army
Yes, as long as you go with an oem-like configuration, the only difference is recirculated vs venting. Between shifts, etc, air is released from the uicp thru the bov. From there it either returns to the intake pipe (recirculated), or (if your ecu is set up properly) it could just vent out to atmosphere, making the hallmark "bov sound" that the fan-boy in all of us love...whether we admit it or not.
In either case, the bov is positioned the same, just the end destination of the released air is different.
Old Nov 10, 2012 | 04:22 PM
llDemonll's Avatar
what yogsaahoth said.
stock, the BOV is mounted on the intake pipe but is directly connected to the UICP. most aftermarket are mounted directly to the UICP and will either vent to atmosphere if you're SD tuned or recirculate back to the intake pipe if you're MAF tuned
Old Nov 11, 2012 | 12:04 PM
code4evo's Avatar
FAVORITE QUOTE OF THE DAY: it could just vent out to atmosphere, making the hallmark "bov sound" that the fan-boy in all of us love...whether we admit it or not.
Isn't that the truth
Old Nov 11, 2012 | 12:20 PM
todd6027's Avatar
It has to be on the pressure side (uicp) theres nothing to vent on the intake pipe
Old Nov 15, 2012 | 10:40 PM
DG39's Avatar
just bought my evo the bov is 100%Venting and on the uicp, i just got the piece to make it full recirc.will it ruin anything by having it full recirc on the uicp?
the car is 100% stock out side of the BOV
Old Nov 15, 2012 | 11:36 PM
evo8426's Avatar
No it will not ruin anything, it is actually supposed to be recirculated
Old Nov 16, 2012 | 10:14 AM
DG39's Avatar
i just saw in an earlier post someone was talking about location for recirc and location for VTA i just put the fitting on the car is way better now, no more stupid sputters on the highway when i let off the throttle.
Old Nov 16, 2012 | 06:53 PM
Jeff Boyd's Avatar
Does running the car on stock tune with a 100% vented BOV not cause idle/surging/throttle issues?
Old Nov 16, 2012 | 11:15 PM
shrtstuff89's Avatar
with it being stock, your ecu thinks that bov air is going back to the engine. if its vented to atmosphere, all that air is being taken away from your engine, causing sputtering, rpm drop, and sometimes stalling.
Old Nov 16, 2012 | 11:40 PM
DG39's Avatar
yeah it was ****ty, 5th gear was the worst every time id take my foot off the throttle or tride to slow down it would jerk. i love that its back to full recirc.
sgtpruitt
Feb 23, 2015 01:56 PM
vicariousthrill
May 27, 2013 03:18 PM
Ralliartize It
Sep 25, 2012 03:24 PM
