Car Problems, PLEASE HELP! Where Do I Start???
Old Dec 24, 2012 | 02:50 AM
Supra2Evo's Avatar
K I need help!!! Here's the story, I approached my street and was down shifting, in 2nd gear slowing down I heard a water pissing noise but I wasnt sure if it was just my brakes or something weird. I got on it all of second, part of third, part of forth and slowed down. Heard nothing. Pulled back up to my house and turned the car off and a little white smoke arose out of my hood vent. I heard air bubbling in my engine system so I immediately turned it back on and opened the cap. I filled up the car with water, it was about half a gallon low.
Now, the facts, my exhaust is smoking very lightly and continuously, but there is no smoke I can see coming out of my dump tube. It appears my radiator has a crack and is leaking about a drop a second at the bottom where my dump tube was to close, and the exhaust gases basically were directed right at that point on the radiator. Now, what should I address? I burped the system and it seems ok, but the slight smoking out the exhaust remains (here's the catch too, I rubbed the water that was in my exhaust tip on my hands and it did NOT become sticky as normal coolant/water mix would). No weird motor sounds, oil level is full. Could I have blown the turbo seals? Floated the head? How do I diagnose? PLEASE HELP!!
Old Dec 24, 2012 | 04:25 AM
WikdEvo's Avatar
Does not sound like blown turbo seals. You'd have a noise and smoke coming from the turbo. You said your radiator is cracked? I'd start by fixing that. To me it sounds like your head lifted. If I were you I'd pressure test the coolant and do a proper leak down test.
I'd also stop driving the car
Old Dec 24, 2012 | 09:58 AM
barneyb's Avatar
Find the source of the leak and replace the leaking part.
Old Dec 24, 2012 | 10:31 AM
tdt1805's Avatar
If you heard the pissing noise why would you get on it?
Old Dec 24, 2012 | 01:45 PM
Supra2Evo's Avatar
I just did my brakes and the pads and slotted rotors I installed make alot of weird noises. Being 3am, and dead tired I just passed it off....
Anyone else have an idea?
Old Dec 24, 2012 | 01:49 PM
Supra2Evo's Avatar
Here's another thing-
After an hour or so I went back out to the garage to check the residue in my exhaust and it was completely dried up and gone, it wasn't sticky at all like coolant would be. While though the coolant that was on the ground was still there, and it was sticky.
So, what gives lol?
Old Dec 24, 2012 | 01:53 PM
SilverShadow03's Avatar
start with your known problem: cracked radiator and go from there.
Did you bleed your brakes? Check your brake fluid and make sue you're not leaking brake fluid at any rotor.
Old Dec 24, 2012 | 02:01 PM
TommiM's Avatar
The non sticky fluid on your dump was probably just condensation. As posted already, fix the known problems. You said your dump is too close to the radiator and now it leaks. Fix or replace your radiator and fix your clearance issue. After thats good pressure test your coolant system for leaks.
Old Dec 24, 2012 | 02:40 PM
Supra2Evo's Avatar
NO SMOKE ON COLD START AT ALL, Car ran for over a minute, still no smoke
Old Dec 24, 2012 | 02:43 PM
Supra2Evo's Avatar
Praying to god its just my radiator is cracked, te smoke last night was just condensation, and my luck isn't to terrible.... Praying!!
To bad my custom CMS Aluminum Radiator is done for though, was gorgeous.....
Going to buy a Forged Aliminum Radiator now....
Old Dec 24, 2012 | 02:46 PM
SLVRcarbonEVO8's Avatar
Get everything completely dry and make sure that's the only spot leaking. Leaks can be so small and in the most random places when they happen
Old Dec 24, 2012 | 02:47 PM
Cal City Evo's Avatar
That was my thought. It's ALWAYS smart to get on it if you are having problems!
Old Dec 24, 2012 | 05:01 PM
WikdEvo's Avatar
Why do you keep avoiding what everyone tells you? After you swap radiators, pressure test the coolant system. Then, I'd do a leak down test.
Old Dec 24, 2012 | 10:52 PM
Supra2Evo's Avatar
Lol.... I didn't think I was having any problems. Car ran strong for months without a single thing going wrong. The noise honestly didn't sound like anything more then rocks grinding on the ground while turning the corner slowing down. After the fact I realized it must of been a water sound....
No arrogant or smart *** remarks needed, thanks....
Old Dec 24, 2012 | 10:57 PM
Supra2Evo's Avatar
I'm not ignoring anything.... I posted earlier that I went and bought the radiator haha....
Of course I'm going to start my car and see if it smokes still and it had cooled down after sitting all night and day.
I'm simply giving updates to help with the details I've already given.
Thanks
