THERMOSTAT Opened valve set temperature 71 Degree Celcius?
Old Feb 15, 2004 | 05:49 AM
x7eVoLuTiOn7x's Avatar
What does this do?
Old Feb 15, 2004 | 06:06 AM
gunzo's Avatar
Ralliart water temp thermostat .. normal opens at 80 degrees celsius ..
What it does is it allows the coolant to start flowing to the radiator earlier .. thereby keeping the engine cooler .. only a problem if you're staying in colder climates
Old Feb 15, 2004 | 06:44 AM
Crazy4Cars's Avatar
It is the other way around, Ralliart opens at 71C, while the oem opens at 80C.
Old Feb 15, 2004 | 07:08 AM
How do you install this? where does it go? any pics?
I live in a HOT climate country, so I guess this is a good mod.
Old Feb 15, 2004 | 07:43 AM
gunzo's Avatar
Yub .. thats what I said .. normal opens at 80 degrees ..
Old Feb 15, 2004 | 07:47 AM
gunzo's Avatar
From the upper radiator hose to the engine ..
Where the hose go into a housing on the engine .. that's where the thermostat is .. you need to take off a couple of bolts that ties auxiliary stuff to the block .. and there's 3 bolt itself that holds the housing down .. the thermostat just pops out once you remove the housing .. make sure the engine's cold though ..
After you do this .. your temp stays like at the 1/4 mark whenever you are moving .. once you stop .. it creeps back to norm ..
Old Feb 16, 2004 | 02:41 PM
EVOVII_SWE's Avatar
Re: THERMOSTAT Opened valve set temperature 71 Degree Celcius?
What does this do?
The idea of this thermostat is to secure a safe egine temperature when suddenly pushing your car very hard. There is a delay in a thermostat so when you do this sudden power burst the engine temp may climb to dangerous hights before the thermostat notice and starts to open. If you have the 71 degrees one installed the normal starting temp is lower so you would never get too high befor it opens.
I hope this made some sense?
Old Feb 17, 2004 | 03:08 AM
thanks alot guys for the explanation...you learn something everyday. Is this mod worth it? Easy to install? Im not mechanically inclined, would it be easy to install?
Old Feb 17, 2004 | 08:11 AM
EVOVII_SWE's Avatar
Since you live in a warm location, it's relatively cheap and some one who knows a bit of working with cars would probably change it in less than 10 minutes I would say it's worth it for you.
Old Feb 17, 2004 | 08:21 AM
gunzo's Avatar
Yes definitely .. I too stay in a perpetually hot place .. the engine runs cooler, everything is cool Performs even better on the track ..
Drawback is on slightly cooler mornings .. the car takes a long while to warm up .. so you gotta watch that spirited driving early in the morning ..
Old Jan 6, 2005 | 08:52 PM
justchil's Avatar
Does anyone know if draining the coolant is required? I'm not sure with the engine being cold if this is needed. There service manual says to drain it
Old Jan 6, 2005 | 09:04 PM
justchil's Avatar
If anyone needs the diagram for thermostat install check this out:
http://www.justchil.net/gallery/evo_...ams/thermostat
Old Jan 7, 2005 | 04:55 AM
justchil's Avatar
Well it looks like you have to drain the coolant. When removing the housing fluid started coming out
Old Jan 7, 2005 | 05:58 AM
Derek Baker's Avatar
Thermostat 101
I did not drain my coolant.
I let what ever spill out of the top radiator hose. Then ran water over the spilled coolant because the coolant is very corrosive to paint and stuff. I removed the 3 bolts on the metal housing to the upper radiator hose. Pulled out the old thermostat. The new one has a rubber seal that will seal it to the housing.
Torque bolts to 10 +- N.M (84 +- 13in-lb)
Then add coolant and distilled water to radiator.
Make sure that all hoses are connected/ then start car with radiator cap off..... Turn heat on inside the car at full (4).
Wait for coolant to cycle through the radiator when the Radiator fan kicks on.....
Add more coolant/ water & then put radiator cap on.
Drive and test for leaks and add coolant to coolant overflow bottle if its low.
Good luck
Derek
Old Jan 7, 2005 | 09:16 AM
justchil's Avatar
Sweet.. thanks for the reply man. Will give this a try as soon as I get home
evo x 7777
Sep 11, 2015 05:36 AM
prashd
For Sale - Cars For Sale
Mar 24, 2015 08:53 AM
rodent
For Sale - Wheels / Tires
Jun 26, 2012 11:16 AM
x7eVoLuTiOn7x
May 3, 2005 08:34 AM
x7eVoLuTiOn7x
Dec 27, 2004 08:25 PM
