Hallman pro mbc problems low boost
Old Mar 29, 2013 | 09:59 PM
evoviiihan's Avatar
I just installed a brand new hallman pro and I hooked it up as the diagrams show where the inlet on the bottom goes to the turbo vaccum source rather than teeing into the bov line and the outlet that's on the side of the mbc goes to the waste gate but I am stuck at factory boost levels for some reason no matter how much I turn it. Oh and I have the nipple on the intake capped
Old Mar 29, 2013 | 11:00 PM
djdnav's Avatar
I didnt read the directions but did you try turning it the other way? Do you have the factory solenoid plugged in/capped?
Old Mar 30, 2013 | 04:21 AM
egis's Avatar
source line(for example from turbo housing nipple) goes to the side nipple of mbc.
Old Mar 30, 2013 | 06:04 AM
steven121's Avatar
Take a pic
Old Mar 30, 2013 | 07:29 PM
evoviiihan's Avatar
really? the diagram i read on here said to put it on the bottom nipple but that was for the evo rx pro now that i looked at it again. does anyone know if their different
Old Mar 30, 2013 | 07:30 PM
evoviiihan's Avatar
yes it is capped and plugged in
Old Mar 30, 2013 | 08:00 PM
RichieVegasIX's Avatar
I don't think your suppose to turn the boost up before you get a tune!
Old Mar 30, 2013 | 08:25 PM
evoviiihan's Avatar
Yes very true but I'm trying to get it working so the tuners can change it as they need I've been trying to get a tune for a while but this had been holding me back
Old Mar 30, 2013 | 08:59 PM
evoviiihan's Avatar
And I was going to just cap the turbo nipple and teeing into the bov line but there is a line teeing into already I think it's for the aftermarket boost gage that was on the car when I bought it. would it be fine if I tee'd into that line again?
Old Mar 30, 2013 | 11:45 PM
djdnav's Avatar
Two things I wouldn't tap into are the fpr and bov vac lines. My hallman Mbc is connected to the outlet on the j pipe and the waste gate actuator.
Old Mar 31, 2013 | 01:33 AM
AdamAndEvo's Avatar
Hey man I just did the same install and I couldn't get over 12lbs. I toot he boost control apart and realized that I wasn't adjusting it at all.. Only screwing the cap on and off.... You really gotta crank it down the first time... After that I just slowly turned it p now it holds 18 solid...
Also idk how installing it upside down only gives you people stock boost ... If you flip it over it pushes the ball the wrong way and the waste gate never opens.... Infiniti boost... I spiked at like 24 ..whoops. Anyways good luck.
Old Mar 31, 2013 | 01:37 AM
AdamAndEvo's Avatar
Also I did the bov line method.... Think about it this way at the j pipe your boost guage sees what the turbo is pushing out.... At the bov you see what the manifold is actually getting... It's kinda like how the wide bands gotta be 3 ft from the turbo to get an accurate reading... Just my opinion. No science or math behind that statement.
Old Mar 31, 2013 | 06:32 AM
egis's Avatar
https://www.evolutionm.net/forums/at...chmentid=21291
OP my apologies for misleading info.this is what i found,hope it helps.
Old Mar 31, 2013 | 10:06 AM
evoviiihan's Avatar
what do you mean crank it down. like screw it down all the way shut or all the way off. and is that how you take it apart? just unscrew the top?
Old Mar 31, 2013 | 10:31 AM
AdamAndEvo's Avatar
I took the bottom nipple off took the ball and spring out and turned it with a screw driver.. But I'm sure if u just twisted hard it would work. The cap should screw down like a inch.
