Grounding Kits
Old Feb 17, 2004 | 03:30 PM
Mattsteg45's Avatar
Grounding Kits
Has anyone dynoed with one of these on to know if they really add the claimed hp? I want one but $100+ for something that doesn't really add 4-7hp isn't in my budget.
Old Feb 17, 2004 | 03:35 PM
2k4EvoVIII's Avatar
Ya i have been thinking about getting one also but i havent seen any dyno numbers. I dont think you will see much on the dyno but it is good to have either way. Let me know what you guys find out.
Old Feb 17, 2004 | 07:11 PM
Appauldd's Avatar
save yourself 75 bucks and make your own. The local stereo shop will have everything you need to make the entire install a breeze.
Old Feb 17, 2004 | 07:20 PM
YellowFever's Avatar
get one from abusivewombat....his kits are excellent and is $35 shipped... here is the link... https://www.evolutionm.net/forums/sh...t&pagenumber=1
Old Feb 17, 2004 | 07:55 PM
kcevo's Avatar
I don't know if it will add any more horsepower, but when I installed mine I have my turbo timer set up to display voltage and it would jump between 12 and 14 volts w/o the grounding kit. With the grounding kit the volts only jump between 14.5 and 14.9 volts at the most usually only see 14.64 - 14.72.
Old Feb 17, 2004 | 08:09 PM
StreetPowerEvo's Avatar
I installed on over the summer and it seemed to smooth out my idle a bit. Also turning on accessories (a/c, headlights, etc) didn't dim my lights as much
