More issues with the Evo
Hello again,
I've come across an issue with my launch control that I have been trying to figure out for awhile. I'm currently on tephra v7 with a mild launch map set up. The car sounds like a Subaru after a few seconds like it is blowing out the plugs or flooding itself out. I also change out plugs almost every 2 weeks and every time they're fouled out and are covered in a sooty black like it's running too rich. My afrs taper down to 11.2 at wot.
After getting out of the throttle the car will regain itself and idle normally and drive fine. The car pulls hard at 24psi on e85 with no issues. The bosch iridium plugs are gapped to .20 and I have the launch control set to -2 degrees timing with 10.5 fuel at 5500 rpms with the table smoothed out all the way up to 3000 rpms. If i try to launch on the map, the car will launch but fall on its face and almost stall out half way through 1st. I will post my maps when i get off work if anybody would like to see them.
I have looked around and found issues with breaking up at wot due to fouled or improperly gapped plugs but none during a launch. The only thing I've been able to think of is my knock sensor being sensitive and causing the car to pull timing.
Any ideas or links to a similar issue would be greatly appreciated!
Rschanaman
Rschanaman
rschanaman
Aug 28, 2013 03:03 PM
