Broken Turbo/Manifold Bolt, Will not budge!
Old May 31, 2013 | 11:35 AM
manthny18's Avatar
have tried everything. even took it to a machine shop they worked on it for an hour (95.00) called me to come pick it up cant drill it out. what are my options here.
Old May 31, 2013 | 11:52 AM
twabtoxer's Avatar
Pics?? Machine shop should have taking care of it
Old May 31, 2013 | 12:31 PM
SilverShadow03's Avatar
How could they not drill it out? Drill it out and retap it or use some form of extractor. It has worked on other broken turbo/manifold bolts.
GL!
Old May 31, 2013 | 12:37 PM
donzilla2004's Avatar
I'm wondering if the machine shop is scared to drill too far and damage the head. They probably don't want that liability on their hands. I would try a reverse bit and see if you can get it out.
Old May 31, 2013 | 12:50 PM
sujinX's Avatar
can u take a pic? is it broken such that the threading is only in the hole? theres none outside?
Old May 31, 2013 | 01:29 PM
ProPilot04's Avatar
If they didn't get it out, get your damn money back... or at least get a reduced rate on the labor?
For $95 I would've sat there yutzing with it with no goal.
Wait... which machine shop did you take it to?
Old May 31, 2013 | 01:58 PM
S3CR3T's Avatar
happened to me once... mine was bad and it was two not just one bolt I took it to a local auto shop got it out for like 45? you should get your money back I wonder if they even tried.
Old May 31, 2013 | 02:14 PM
manthny18's Avatar
ill post pics up later. just bought like 6 cobalt drill bits gonna take another shot at it. and it dosnt look like they tried very hard. it was NorthEast Machine.
Old May 31, 2013 | 02:45 PM
90zcrex's Avatar
If a machine shop couldn't get it out in an hour then they're not really a machine shop.
Old May 31, 2013 | 04:06 PM
hiboost2.0's Avatar
Is it completely flush? If not take a nut and a washer, thread a bit of the nut onto the stud. Weld it onto the stud and use heat around where the stud enters the head. I wish you were closer, I would definitely help get that sucker out for you.
Old May 31, 2013 | 06:20 PM
19DB794's Avatar
Happened to me when I was installing my o2 housing. All we did was cut off the rest of the broken stud and then drill it out on the drill press while using some cutting oil. Then I just got a copper nut and bolt instead of pressing in a new stud.
Old Jun 1, 2013 | 06:38 AM
Andrewkbmx's Avatar
Get a torch and double nut it if possible or just drill it out
Old Jun 1, 2013 | 02:52 PM
manthny18's Avatar
got them off yesterday with the new drill bits took literally 10=15 min for both. cobalt drill bits FTW ate threw the broken bolts.
Old Jun 1, 2013 | 03:24 PM
BEKevo's Avatar
Nice!
Old Jun 1, 2013 | 03:29 PM
EVO KNVL's Avatar
Go back to the machine shop and show them how it's done. Maybe do a write up for them. lol
