Are sway bar bushings important??
Old Jun 28, 2013 | 10:24 AM
88888's Avatar
I took my perrin rear sway bar to repaint it.
repainted it.
remounted the sway bar but now, the bushings that attach sway bar to the body is loose and are worn out so the sway bar moves left and right before end links are mounted.
I was wondering if this was an issue.
Is sway bar supposed to stay still on body while cornering?
thanks
Old Jun 28, 2013 | 10:42 AM
ReaperX's Avatar
The bushings are what keep the sway bar located in relation to the attachment point. The bar will move slightly left to right and up to down within the bushings. Like with any worn bushing, it will give whatever it is attached to more room for play. If there is excessive play it could shorten the life of the part.
If it is worn and there is excessive play, replace the bushing.
Old Jun 28, 2013 | 02:06 PM
ProPilot04's Avatar
Yes. You need to replace those.
Old Jun 28, 2013 | 02:10 PM
mdsevo06's Avatar
You can find new ones on ebay and rockauto for a good price.
Old Jun 29, 2013 | 07:01 PM
BMS Evo's Avatar
repainted it.
thanks
I believe Whiteline offers replacement swaybar bushings if that's what you mean is worn out?
Old Jun 29, 2013 | 09:15 PM
barneyb's Avatar
Any free movement of the bar in the bushings means more body roll.
Old Jun 29, 2013 | 09:29 PM
cfdfireman1's Avatar
left right movement is OK. up down front back movement is not.
nickleo373
Mar 23, 2016 10:35 AM
turbotalawd
Jul 16, 2014 10:17 PM
BigDee
22
Jun 27, 2012 08:10 AM
mcgarvey
Dec 1, 2007 12:55 PM
