First trip to the 1/4...This normal??
Old Jul 16, 2013 | 04:58 PM
  #31
jordanwince's Avatar
Originally Posted by xRoguex
can you post the full slip?
No scanner at my house unfortunately...Ill write it out:
Dial:
R/T: .171
60': 1.947
330: 5.573
660: 8.595
MPH: 82.30
1000: 11.258
/4: 13.450
MPH: 105.87
Originally Posted by sLUg_
Step 1: Set 2 step at 5500
Step 2: Practice Slipping clutch on launch to eliminate the bog
Step 3: Skip water box
Step 4: Rev 4th gear out. DO NOT Shift into 5th!
These steps might help a beginner out.
PS: I personally know a guy here No Lift Shifting on a 9 turbo tuned on e85 making 360awhp and he still runs 12.0s. I suggest working on your launch and your 1-2shift. Thats the money maker and the rest is easy. Goodluck
I will do. This track had no space to go around the water box unfortunately..
Old Jul 16, 2013 | 05:18 PM
  #32
sLUg_'s Avatar
Yea I would set the 2step a little higher. Might be bogging down a little a 4.5k. Also try launching at 5.5 and part throttle untill you feel it hook then mash and go through the gears.
Old Jul 16, 2013 | 05:42 PM
  #33
AreSTG's Avatar
Dial:
R/T: .171
60': 1.947
330: 5.573
660: 8.595
MPH: 82.30
1000: 11.258
/4: 13.450
MPH: 105.87
i bet it's the shifts. I'm not saying you don't have room to improve the 1.9 60ft, but, it can be a LOT worse than 1.9. Now, looking at your 1/8 mile time- that is telling me your shifting is slow. 8.6 sec makes me think your shifts are taking far to long, resulting in your ET: losing a lot of momentum in the shifts, and stock turbo or not, it has to spool up again.
Anyway, practice practice, practice! once you get the launch right, you'll know
Old Jul 16, 2013 | 07:43 PM
  #34
alex:)ix's Avatar
MadMsheenTuned is your tuner?
i ran 12.4 at capitol raceway last year and im on e85 tuned im not proud to say that!!!
figured out with my friends the tires were the problem i have four season tires worst tires am running on my evo trust me...
good tires can help to cutting the 60 down bro
alex
Old Jul 16, 2013 | 08:08 PM
  #35
lostsoulsevo's Avatar
from your times, it looks like you're shifting slow and shifting at redline. your 1/8 mile time should be 8.2-8.3 at 82mph, 105 trap should be 12.5-12.8 if you can get that 60ft down.
Old Jul 16, 2013 | 08:25 PM
  #36
boosted91t's Avatar
Try cecil county next time. I do like that track better then the others in the area. It's just a hike for me!
Old Jul 16, 2013 | 08:40 PM
  #37
hiboost2.0's Avatar
Originally Posted by egis
And all this on stock 8 turbo and 93 octane?thats amazing!
Can't tell if sarcasm. But yes and no. 93 octane with an evo 9. Intake, turboback, ic pipes, and tune.
Old Jul 16, 2013 | 09:33 PM
  #38
heavens turbo's Avatar
my first time at the track was 14.2, 1.6 react, 98mph trap. all stock with crap driving. it was fun though. but yeah, you should be in the 12's if you don't suck.
Old Jul 17, 2013 | 05:59 AM
  #39
Raptord's Avatar
Reaction time doesn't affect your ET.
Old Jul 17, 2013 | 07:44 AM
  #40
egis's Avatar
No sarcasm here.thought it's on 8 turbo.still impressive.
Old Jul 17, 2013 | 12:59 PM
  #41
ProPilot04's Avatar
FWIW, my launch control is set at 5850. 4500 is definitely too low though... you're going to get a ton of bog there.
Old Jul 17, 2013 | 01:07 PM
  #42
Ill have to check it out and see. I was constantly watching the light.
Old Jul 17, 2013 | 01:25 PM
  #43
ProPilot04's Avatar
FWIW again... at the track, when you're learning, especially in an Evo, the light is the last thing to worry about.
A common thing to do is to just wait for the car next to you to go, and then a second or two after that, you can go.
It'll give you some time to practice your launch without the pressure.
I've flown lots of airplanes, and launching the Evo properly at the track is damn near as complex as getting some of these planes off the ground.
Old Jul 17, 2013 | 09:00 PM
  #44
AreSTG's Avatar
that's cuz the Evo has no checklist
Old Jul 18, 2013 | 01:47 PM
  #45
ReidFletcher's Avatar
Just take your time, your RT doesn't count against your ET. Killing 0.10 out of your 60' cuts 0.20 off at the big end. The 60' is more important part of a drag strip.
