low speed clunking in stop & go traffic
Old Jul 16, 2013 | 11:39 PM
VWJETTY's Avatar
i was wondering if this was something normal. in low speed, it's like something is "clunking" in stop and go traffic but fine when moving or on the freeway. sometimes it makes this noise when I'm turning the steering wheel as well. Thanks.
Old Jul 17, 2013 | 01:05 PM
ProPilot04's Avatar
This could obviously be 1000 things, and I'd suggest that you just check your front end for looseness. You know, yanking on the physical wheels to see if the bearings or ball joints or tie rod ends are shot.
But typically, it's your downpipe clanging on something (T-Case).
Old Jul 17, 2013 | 08:33 PM
Craig King's Avatar
Does it sound like it's coming from the rear end? I know after STM put new rear-end fluid in my car, (something thicker), it clunks. They said that is normal at low speeds.
Old Jul 17, 2013 | 10:50 PM
VWJETTY's Avatar
yeah, that's true. there could be a million things going on here.
but yeah, front end noise. i'll follow up. thanks.
Old Jul 17, 2013 | 11:29 PM
allevolution's Avatar
mustache bar?
Old Jul 17, 2013 | 11:52 PM
17pstockcar's Avatar
I would guess that its some kind if mount.
Could be motor. Gearbox. Tcase. Exhaust. Diff etc even driveshaft
Old Jul 18, 2013 | 12:08 AM
shrtstuff89's Avatar
Check all the bolts on the suspension system. If the bolt on you control arm goes missing, you can get this sound.
GetterDragun
21
Oct 24, 2013 02:02 PM
Dr.Sound
Feb 2, 2007 04:50 PM
platinumspecv
Dec 17, 2004 07:21 PM
Ultor
May 21, 2004 09:06 AM
JT-KGY
Mar 23, 2004 10:37 AM
