figured out the boost cut issue
Old Jul 25, 2013 | 08:31 AM
impact blue's Avatar
Okay now the evo9 issue that I had that cut boost here's what I did. Now first I thought it was the tune checked the tune same result with the car running lean and cutting boost.
Now we tried taking the tune and reflashing it to stock we got the same results. Then we tried putting the flash on the car then we tried to check the car for codes the tech used a snap-on scanner the real expensive one the issue came up with the mad sensor. All that time the issue was with the mad sensor s.o.b all that time and frustration over one sensor replaced it with a stock replacement the car stopped running piggy rich at idle.
The next issue with the mad sensor was that even though it was plugged in we reset the code and it came right back. At least its confirmed and now I'm boosting 25 spike 22 red-line.
Old Jul 25, 2013 | 09:02 AM
egis's Avatar
Glad you found the problem.
Ozrally-king
Lancer Troubleshooting
Sep 16, 2014 11:24 PM
lancerMXV6
Aug 20, 2013 08:06 PM
EVIIILJ
Jan 10, 2013 12:12 AM
Mad_SB
09+ Ralliart Show and Shine
23
May 4, 2012 05:42 PM
BEISSEN
16
Jun 26, 2011 05:36 PM
