06 evolution idle problem
Old Aug 20, 2013 | 08:37 PM
mitsuman06's Avatar
Hey guys I'm new to the evo, just got my first one but I got a slight rough idle. It goes up and down sounds like as well a lil mis, I've notice all vacuum lunes are zip tie I have ni codes, and just put a fresh new plugs, any ideas anyone. Few mods like exhaust and intake and manual boost controller. Can someone please help.
Old Aug 20, 2013 | 09:06 PM
the_evodude's Avatar
boost leak test
Old Aug 21, 2013 | 02:28 AM
mitsuman06's Avatar
Ok ill try test, thanks evodude
Old Aug 21, 2013 | 05:06 AM
CaptainSquirts's Avatar
The Dude Abides.
Old Aug 21, 2013 | 08:31 AM
mitsuman06's Avatar
I tested, everything good, double check vacuum lines and are good, I did unplug MAF and idle was perfect I connected it back and starts a rough idle again does that mean its bad, again I have no codes either.
Old Aug 21, 2013 | 08:34 AM
rjfg's Avatar
Afr gauge??? Check your afrs at idle. Could be tune time.
Old Aug 21, 2013 | 08:56 AM
w33zy's Avatar
Check the MAS (MAF) and clean if necessary..Good luck.
https://www.evolutionm.net/forums/ge...-cleaning.html
https://www.evolutionm.net/forums/ev...f-cleaner.html
Old Aug 21, 2013 | 09:19 AM
Nero_slk's Avatar
IACV valve...
In my case it was the HKS BOV - needed a good clean inside as had a build up of dirt
Old Aug 22, 2013 | 09:17 AM
mitsuman06's Avatar
Have a stock bov, and at idle my afr is like 15 to rich
Old Aug 22, 2013 | 09:49 AM
mitsuman06's Avatar
And the tuning is stock
Old Aug 23, 2013 | 10:09 PM
IgotabigEVO's Avatar
I had the same problem awhile back ended up being the egr valve. Replaced it and problem solved.
Old Aug 26, 2013 | 07:36 PM
mitsuman06's Avatar
Would I get a code, if egr is bad? Just got back my evo and they replaced MAF but the rough still continues...
Old Aug 26, 2013 | 07:55 PM
Randal's Avatar
Guest
Are you sure you don't have Cams?
Old Aug 27, 2013 | 10:10 AM
flippymcbean's Avatar
is your RPM jumping at idle? or is it just the exhaust note going up and down?
Old Sep 6, 2013 | 05:59 PM
mitsuman06's Avatar
It idles and then starts to feel like a mis and then its fine but idle then wants to die out, and my afr goes up and down when it feels like missin it reads 17 and then it reads back to 10 idling fine but then back to miss and reading 17 again any ideas
