3 vs 3.5 vs 4 inch downpipes
Old Aug 22, 2013 | 03:30 PM
5LEEPERISAH23I's Avatar
So I know im going to get a lot of mixed answers and no straight answer, I know that before even posting this.
If you are making 750whp / 800whp with 35-40 PSI what would be the best downpipe size to run?
I KNOW a 3" would work and has been proven but it doesn't mean it is the best size to run at the hp level.
As of right now im leaning towards a 3.5"
Let me know your thoughts!
Old Aug 22, 2013 | 07:07 PM
EvoVIII856's Avatar
i would think when you go 3" intercooler piping at that much power to also go 3.5" exhaust.
Old Aug 22, 2013 | 07:36 PM
Abacus's Avatar
Not sure it will be worth the upgrade on the stock framed Black. Do you have a back pressure sensor on your current setup? It would be really good data if you decided to log it and then make a change.
Old Aug 22, 2013 | 08:20 PM
no i dont but im going 6466 V-Band
Old Aug 27, 2013 | 04:47 AM
Roadrunr's Avatar
Good read on your question.
https://www.evolutionm.net/forums/ev...5-exhaust.html
Old Aug 27, 2013 | 07:35 AM
Steven's Avatar
I've been wondering the same thing. I'm doubtful that I'll pick up much power though when you factor in that the exhaust is 3" and the wastegate dump is is bigger than 1.5". I hit 40-45psi just a little over 5K rpm and then the wastegate opens to hold it there. I'd love to see more comparisons though!
Old Aug 28, 2013 | 03:06 PM
Evo_Precision's Avatar
Neither a 3" or a 3.5" is going to cause any meaningful restriction at that power. 3" will work fine and be lighter. 3.5" will be louder, that's about it.
dalinkwent
Jan 13, 2017 06:04 PM
iheartmyevo89
Oct 24, 2016 09:09 AM
The4sakenone
Jul 22, 2015 10:12 AM
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
gl4662
Jul 2, 2007 01:12 AM
