Weird AC problems. 2 Fold
Old Sep 15, 2013 | 05:48 PM
  #31
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by J_Striker
I'm confused at the question, Freddie. Are you wanting me to unplug the pressure switch and jump it or unplug the a/c clutch and apply power to see if it works?
No the trans clutch switch...
Old Sep 16, 2013 | 12:02 AM
  #32
Socal's Avatar
Originally Posted by SmurfZilla
You're having this issue as well? I sent message to Tephra but I doubt he'll respond. I can't believe this is the first time anyone has brought this up but I can't any info on this as it relates to the ECU.
Do you have the same problem we have (Compressor doesn't turn on at idle but works when you start rolling.
I'll try the one bit I found and flash my ECU tomorrow.
Yea, I am having the exact same problem. I still can't figure it out. Keep us posted if the ecu fixes it.
Old Sep 16, 2013 | 10:36 AM
  #33
Veteran: Navy
what rom ID are you guys using? Also have you unplugged the transmission clutch switch to see if that effected the operation...
Old Sep 16, 2013 | 12:30 PM
  #34
SmurfZilla's Avatar
It didn't change anything. All it did was make me have to pop the clutch in order to get it started.
Old Sep 16, 2013 | 12:37 PM
  #35
SmurfZilla's Avatar
I haven't tried that. I'll try it when I get back from business travel.
I'm on 88591715.
The second poster said he was fine until he went to V7 thats what had me thinking it was an ECU thing.
Old Sep 17, 2013 | 02:26 PM
  #36
2gsxtasy's Avatar
You guys are all having this issue - do you all still have the stock AC fan? If not, I wonder if there is some sort of relay that does(or doesn't) get triggered with it's removal?
Old Sep 17, 2013 | 03:48 PM
  #37
SmurfZilla's Avatar
No I'm halfcut/single radiator fan. I don't remember my blue evo having this issue and it was the same halfcut radiator setup with a more inferior ac setup then now.
Old Sep 17, 2013 | 07:27 PM
  #38
J_Striker's Avatar
Stock fans here.
Old Sep 17, 2013 | 09:47 PM
  #39
Socal's Avatar
I'm running stock fans as well
Old Sep 19, 2013 | 12:18 PM
  #40
SmurfZilla's Avatar
Anyone tried Freddie's suggestion yet?
Old Sep 19, 2013 | 01:50 PM
  #41
blowngasket's Avatar
Another thing to check is the Power at the compressor at idle, If your getting power or not.
If you are then its your clutch not fully engaging until the RPM goes up beacause of centrificle force on the pully.
Check your Rom and see what the AC Idle says too.
Old Sep 19, 2013 | 01:51 PM
  #42
Old Sep 19, 2013 | 03:45 PM
  #43
J_Striker's Avatar
Its not getting power at idle. And, after it was engaged at a higher rpm, why would it stop being engaged at idle? Centripetal force would actually hamper it engaging.
Old Sep 19, 2013 | 08:47 PM
  #44
SmurfZilla's Avatar
+2 its not getting power at idle.
  #45
SmurfZilla's Avatar
I'm looking now but where is that located?
