Is it me or does the HOOD of EVO dent easily?
Old Feb 29, 2004 | 04:28 PM
JohnnyChimpo's Avatar
Originally posted by ImportUpgrade
no what he means is that some companies specifically for the aftermarket ricer crowd, use a fiberglass base then lay carbon fiber with resin over it to cut costs. Some companies use dry carbon fiber some use the cheap wet carbon fiber. While the dry is lighter, more durable, and more expensive. The wet carbon fiber can be viewed as brittle under the same abuse a dry carbon fiber piece would withstand. CF is made to crack, but wet carbon fiber cracks a lot easier compared to dry carbon fiber. As you said, anything will crack under enough pressure, but some crappy carbon fiber products out there give misconceptions about ALL carbon fiber products.
That's odd that you say that a dry carbon is more durable than a "prepreg" wet carbon. I was under the impression that the wet carbon, being that it is completely soaked with resin, would in reality be bubble free and therefore stronger.
Old Mar 1, 2004 | 07:35 AM
snoop's Avatar
Has anyone upgrade from a damaged stock hood to a CF?
Which hood would people suggest to get?
Old Mar 1, 2004 | 08:25 AM
Boosted's Avatar
gialla looks yummy... but its what 1800 bucks?
Old Mar 1, 2004 | 08:30 AM
mifesto's Avatar
i was told carbon fiber won't save you much weight at all compared to the alrighty light-weight aluminum evo hood
Old Mar 1, 2004 | 09:39 AM
mitsuorder's Avatar
and it will insulate more heat than the stock aluminum hood in the engine bay
Old Mar 1, 2004 | 10:19 AM
hotrod2448's Avatar
Dry carbon is preppreg, wet is where you lay resin into the fabric. Dry is better because it has less resin content and is therefore lighter and more flexibe. The resin is not what gives the piece it's strength it's the fabric. As far as weight savings look at www.allamericanracers.com they are the ones that built the hood and trunk on the sparco evo with a significant weight savings. I believe the parts are located in the aftermarket section. Carbon is also more conductive than alumn so, it should dissapate heat better than the factory hood.
Old Mar 1, 2004 | 09:12 PM
Thanks for carbon lesson professor I assumed that prepreg, since it was "wet", was wet carbon....silly me. It all makes sense now since you explained it though. I just figured that since most carbon used on the body panels of cars is used for looks and some weight savings, that it was a combination of the resin AND the carbon fabric that created it's strength. I understand that carbon fiber, when actually used for strength, is layed out in a direction to give the part maximum strength(such as an airplane wing). But for aftermarket purposes, don't you think that the carbon fiber is really only as strong as cloth fiberglass since both would crack just as easy as the other?
bbong
Jan 13, 2014 03:14 PM
Cyrax91
Aug 17, 2013 07:47 AM
InitialE
Northeast Region
Sep 28, 2008 09:46 AM
DevilDuck
Midwest Region
Aug 11, 2008 08:49 AM
