New Evo VIII owner..help with rough idle.
Old Oct 24, 2013 | 07:19 PM
flippymcbean's Avatar
What's your vacuum at idle?
Old Oct 25, 2013 | 04:49 PM
dsmluck's Avatar
Originally Posted by boostin gsr
when it said random misfire, what was the code? the last number means a lot
Not sure. Only popped once at idle. What do the different number mean?
Old Oct 25, 2013 | 04:51 PM
dsmluck's Avatar
Originally Posted by Ian0611
Try replacing the MAF. I had a similar issue on mine and the MAF was the culprit.
Cleaned it. Has no carbon buildup but if I cant find the culprit soon I may have to just start throwing parts at it.
Old Oct 25, 2013 | 04:52 PM
dsmluck's Avatar
Originally Posted by tormaschy15
+1 on that^, this has happend to me many of times, or vacuum leak? theres alot of dumb vacuum lines for the EGR system behind intake manifold. air in coolant will do it too. and MAFs are spendy, so id try everything else first. if non of that fixes it, could be the sign of a weak fuel pump aswell, too bad you didnt have a wideband to tell us what your A/f ratio was doing
good luck
Yea it may be time to get a tactrix and wideband/boost gauge...
Here is a video I took of the idle. In it i turn the AC on and off. AC idles much worse and you can hear a vibrating noise. Non-AC doesn't make noise just rough with a miss here or there. Part of the vibration noise is the phone on the steering wheel vibrating.
Also here is a video of a track day a few weeks back with me chasing my brothers CTS-V. Doesn't seem like I have any power loss. Drives normal...
Old Oct 27, 2013 | 07:41 PM
MileHighX's Avatar
Are you in CO? Looks like high plains.
I bought my car from IL and it ran ok when I first got it. I did some upgrades and had it tuned and it ran so much smoother. Not saying this is your problem but I do notice my car will sometimes randomly drop rpms at idle, and I have stock cams. Good luck.
Old Oct 28, 2013 | 10:23 AM
boostin gsr's Avatar
it will tell you which cylinder is misfiring. my car threw a p0300 code, which is the misfire code, which was caused by my cams. if it threw a different number at the end then i would have worried, but i knew my cams caused the code
Old Oct 28, 2013 | 02:15 PM
TheBigD's Avatar
thats an odd rough idle, does look like a vacuum leak or air in coolant to me. does it only do it when the AC is on? or all the time? if its only with the Ac the sketchy rough idle is normal. or it was with my car anyways
Old Oct 29, 2013 | 10:27 AM
manolo2011's Avatar
when bought an 06 gsr everything lookd stock but actually it had an aftermarket BOV and that was the issue with my rough idle. just check that FYI...
Old Oct 29, 2013 | 04:39 PM
dsmluck's Avatar
Yea its High Plains. Thought about getting it tuned to see if it will help but i don't want to waste the money on a pump gas tune when I want to go E85 in the next year anyways.
Old Oct 29, 2013 | 04:42 PM
dsmluck's Avatar
Well it was just barely noticeable with AC off before but since I cleaned the ISCV and sprayed the throttle body down with some carb cleaner is runs rough all the time. Not sure if it was a coincidence or i messed something up...
Old Oct 29, 2013 | 04:43 PM
dsmluck's Avatar
I have been over all hoses and vacuum lines. Guess if wouldn't hurt to do a boost leak test.
Old Oct 29, 2013 | 05:34 PM
AJCaron12's Avatar
Do not start throwing parts at it. Do not replace the MAF sensor just because. I don't see how air in the cooling system will cause a rough idle...? Pull a spark plug and inspect the condition of them. Diagnose this thing properly. Don't waste money and dart parts.
Old Oct 29, 2013 | 11:11 PM
TheBigD's Avatar
By chance your intake ismt loose is it? Cause if your bring un metered air in after the MAF might cause an issue like that
Old Oct 30, 2013 | 05:29 PM
dsmluck's Avatar
I have diagnosed the following.
-Spark plugs changed. They looked normal.
-Compression 145 across the board.
-ISCV cleaned. Seemed to function fine. No carbon buildup.
-Recirculated throttle body to EGR vacuum lines.
- Maf cleaned.
-Visually inspected timing belt.
-Visually inspected vacuum lines.
-Reset ECU.
-Mixed in a few gallons of E85 per tank to try and clean out any fuel line gunk.
The only lead I have found so far is that after I cleaned the ISCV and sprayed some cleaner into the throttle body the issue has gotten worse. I noticed that a tiny bit of the black ring on the manifold side of the TB started to run. Don't know if this made the issue worse or could it be an issue with the ISCV or TB?
Old Oct 30, 2013 | 06:25 PM
meckert's Avatar
So you had a random misfire code...At one point I had the same. One of my wires for one of the coil packs was not firing all the time.. Now it only set off a code once. But the misfire could be felt in the gas pedal ( for me) and certainly accounted for a rough idle and lack of power , as it was hitting every few cycles. Start the car and check the plugs for fire--it will idle smoothly, so no rock but will have a weak spark or none at all---you will here it when you pull the coil.. I have spark tech so a little easier to diagnose.
