need tune?? Noob help
Old Nov 17, 2013 | 02:58 PM
Slow208's Avatar
Hey everyone I'm new here this is my first evo. 03 evo 8 I love it it has a few nice mods I bought her about a month ago from a guy and it was all good he told me it would need a tune and so I got on here did research and I checked the car everything healthy but after a while of highway driving at about 65 mph it would stutter like a fuel cut type of thing. I checked around here and most posts said a tune would help. I'm just wondering if that's the case or if my problems really worse. I have a appointment with English to tune on Monday. Thanks for taking your time to help
Old Nov 17, 2013 | 03:27 PM
cfdfireman1's Avatar
What mods have been done to the car? Did the previous owner say it needs a "tune" or a "tune up"? Might just need a fresh set of plugs.
Old Nov 17, 2013 | 03:44 PM
JaYr_EvO9's Avatar
^^^ If your doing a tune which i recommended cause you dont know who did if before but they recommend new plugs so might as well change them
Old Nov 17, 2013 | 04:15 PM
meckert's Avatar
Constantly baffles me, the owner told you it needed a tune a month ago but you wait until the night before bringing it to a great tuner to check into the issue now that you have problems. If a set of plugs is the only expense you encounter count yourself lucky. This aint your moms kia.. small mistakes have big prices.
Old Nov 17, 2013 | 11:46 PM
Slow208's Avatar
Yea I know pretty dumb I just never posted about my issue I read others with similar issues. But yea I'll change the plugs for sure
Old Nov 17, 2013 | 11:47 PM
Slow208's Avatar
What should I use ngk iridium? I heard not to spend the money for those what's best? Thanks for the feedback guys I'm learning
Old Nov 18, 2013 | 01:54 AM
Viegasjuice's Avatar
Most likely needs a tune. Def new plugs, run ngk bpr7es
Old Nov 19, 2013 | 01:52 PM
black_beauty's Avatar
^ I didn't have any luck with the BPRxES. My car broke up at higher RPM's. I run the BR8ES...
Old Nov 20, 2013 | 03:57 PM
Black_EVO_MR's Avatar
op, I had similar issue not long ago, every time I hit boost at around 4K in any gear the car would stutter and had problems getting boost, I put some fresh fuel in it, 93oct, fuel injector cleaner, ran half a tank and then added another one, problem got a lot better and wasn't doing it as much or as bad, changed my spark plugs, problem got even more better, did a compression test, showed good result, then changed plugs for cylinder 1 and 3 and now the problem went away. I only changed plugs for 1 and 3 is because when the check engine light came on it showed those cylinders misfiring.
Old Nov 20, 2013 | 03:59 PM
ctfpevoVIII's Avatar
I would recommend the br7es or the br8es if you want a plug 1 step colder. My advise would be to ask English what they recommend you run.
Old Nov 20, 2013 | 05:26 PM
slowsrt4:('s Avatar
Bpr7es for a few bolt ons, bpr8es if you are running a ton of boost
Old Nov 21, 2013 | 06:14 PM
Slow208's Avatar
Thank you everyone I have a few bolt ons not much but I got it tuned and the new plugs helped a ton it doesnt shutter anymore it does misfire every few seconds so im going to gap them again and see if it changes. Definitely getting bpr7es
mgrover1
Sep 23, 2015 09:46 AM
302Squill
Mid-Atlantic Region
Aug 21, 2015 09:22 PM
jonathanrivera
Dec 12, 2010 03:09 PM
ccboy37373
Jun 16, 2008 11:30 PM
