No g force pull feel !!!
Old Nov 22, 2013 | 12:13 PM
JDM.Spec's Avatar
My car is a ix MR, with a milage below 10000km, just after buying it i realized that it is not pushing as hard as it should. I had problem with the clutch and upgraded it to exedy Stage 1 HD with flywheel, but still the problem is not solved, the car is fast but there is no 'G' force feel,i checked the boost and plugs but everything is fine.... years back i took a ride in my friends ix GSR and that had strong 'G"
feel and the car was stock, and compared to that my one seems to be riding rpm and no climbing in power......
HELP PLEASE!!!!
Thanks In Advance.
Old Nov 22, 2013 | 01:01 PM
kanovic's Avatar
You might just be used to the power. Mine seemed fast to me and after 6month I was like meh it's slow.
Old Nov 22, 2013 | 02:25 PM
ReaperX's Avatar
Have you had it tuned?
Old Nov 22, 2013 | 02:35 PM
hiboost2.0's Avatar
You boost leak checked it? Do you have evoscan and virtual dyno?
Old Nov 22, 2013 | 02:53 PM
kpt6's Avatar
Have someone else drive it while you sit in the passenger seat.
Old Nov 22, 2013 | 10:04 PM
whotippedmycow's Avatar
This is what you need to do! Most likely you have boost leaks. I would replace your OEM clamps with T-Bolt Clamps (set on ebay for like $35) and also your Throttle Body seals could be bad to. I replaced both of those on mine and it was like a brand new car once I fixed my boost leaks.
Old Nov 23, 2013 | 06:39 AM
JDM.Spec's Avatar
No it is totally stock, except ralliart drop in filter.... and for this issue i replaced my cat with a test pipe but the whole exhaust is stock, now the car seems much faster but still no pull feel :/
Old Nov 23, 2013 | 06:44 AM
JDM.Spec's Avatar
and i've checked the boost, my mechanic said boost is perfectly fine... but he checked with some gauge installing with the intake manifold and i have no idea about that.... and i dont know if his procedure was okay or not.... now i'm waiting for my gauges to arrive,DEFI....
Old Nov 23, 2013 | 06:52 AM
JDM.Spec's Avatar
And i've tried being in passenger sit while being driven by some other person but still no difference and it feels like the car isnt getting much power at higher rpm like as it should get....
no it is not tuned, it is totally bone stock....
Old Nov 23, 2013 | 06:53 AM
JDM.Spec's Avatar
yes... a friend of mine got a evoscan... any suggestion??
Old Nov 23, 2013 | 07:37 AM
Viegasjuice's Avatar
Stock Evos aren't fast. Get yourself a tune and then report back.
Old Nov 23, 2013 | 08:06 AM
ctfpevoVIII's Avatar
Well they are fast , low 13 sec 1/4 mile stock. He is right in the sense that after 100 mph they do seem to fall on there face because the stock tune. The stock tune is not very optimal as it runs very rich and it drops a lot of boost at higher rpm.
Old Nov 23, 2013 | 08:48 AM
slowsrt4:('s Avatar
Turn the boost up and sit in the passenger seat
Old Nov 24, 2013 | 05:05 AM
egis's Avatar
Op used to the power.if everything checked out good mechanically it must be it.for example I've been running on e85 all summer and thought ok I like it but it's not fast car anymore, now I'm on 93 octane and it's crazy differences.
Old Nov 24, 2013 | 09:23 AM
Still think you got boost leaks
