Let's see your goals or projects for 2014
Old Jan 1, 2014 | 09:38 PM
Grimgrak's Avatar
600whp on dynojet on a gt3076.
Going from single scroll to dual scroll
Magnus intake
Bigger t4 1.06 turbine housing
Then if needed a full jeff bush head port job to hit my magic number.
I'm already at 547.
Old Jan 1, 2014 | 10:16 PM
AceCampano's Avatar
1) drive it less, keep the miles down.
That's basically it lol.
Old Jan 2, 2014 | 08:00 AM
thepoint4life23's Avatar
Get my front bumper repainted!
Do the diff mod.
Corner Balance
get a ported 9 turbo
1100cc injecters and e85!
Old Jan 2, 2014 | 08:32 AM
ptm5070's Avatar
GSC S2 cams
FP red bb
beehive springs
ti retainers
timing belt
water pump
oil pump
AMS intercooler
IC piping
Speed density intake setup
Tune
xxr 527
roll fenders and touch up paint
JDM rear bumper
JDM tails
1000 cc injectors
port IM and EM manifolds
Whoop some *** at autoX
Old Jan 2, 2014 | 08:42 AM
jake92695's Avatar
MHI turbo
Injectors
Fuel pump
Dodson deep transmission pan
new rims (Enkei, or SSR)
Old Jan 2, 2014 | 08:46 AM
DSMdynamic's Avatar
I hope to get my car put back together and dyno around 6-700whp. I might make a build thread sometime in the next few months.
Old Jan 2, 2014 | 08:51 AM
AWDBus's Avatar
Small goal of 450ish whp/stock block (no access to E85 )
Coat and install turbo kit
install FP4r cams with Super Tech Dual Valve springs
Kiggly HLA
Do timing belt
Install Map ported Intake manny/EGR Delete (at head)
Install Evo MR struts
Get car repainted again
Repaint Calipers due to chips and light fading
Purchase
New clutch
Might swap to Speed Density
Retune
Maybe time for a 2.4 LR stroker or some sort of engine build.
Old Jan 2, 2014 | 09:26 AM
JayTheGrappler's Avatar
My Goal for 2014 is to trade in my 11' STI sedan for a 14' WW Evo GSR!!!!
Old Jan 2, 2014 | 09:31 AM
WikdEvo's Avatar
I bought my evo in 2013 and went from a 300 hp stock evo to a 575 hp v8 killer on E85. The 575 setup was with a Kinugawa 25g. Current goals now are to run low 10's on stock block. This is my new setup and i'll keep this turbo setup for the rest of 2014 most likely.
2014 main goals:
run low 10's stock block and then build the motor afterwards. I really have no direction for this car. It's just a horsepower addiction and trying to beat all the v8's around here.
Old Jan 2, 2014 | 10:32 AM
adriano_917's Avatar
^^^^^^^^^^^ 575hp with a Kinugawa 25g, what WG were you using ? and how many psi ?
Old Jan 2, 2014 | 10:49 AM
WikdEvo's Avatar
Used the Map external o2 housing and that was 32 psi on e85
Old Jan 2, 2014 | 10:55 AM
Red Rogue's Avatar
Paint New carbon front bumper
Install Led Strip Fog Lights that I've been sitting on since November
Buy and install FMIC and IC Piping
Buy and install ETS Dump DP
ReTUNE Evo
Find & Buy JUN CF lip and JUN Underbody (Nighmare)
New Tires :S
New Spoiler or CF Trunk or ???
Old Jan 2, 2014 | 11:07 AM
tarmac_black's Avatar
Well, I just bought my first evo, completely stock with 80k on it. I have many plans, I will list the main ones!
1. Turbo-back exhaust
2. New summer Rims (once winter passes, I'm in Michigan)
3. Intake
4. Tune
5. Walbro 255
6. Short throw
7. Turbo Timer
8. Boost gauge, oil gauge, and wideband
9. Take it to the drag strip!
There's many more, and these are all simple stuff to start. Hopefully some of these will be accomplished shortly!
Old Jan 2, 2014 | 12:13 PM
TheBoz's Avatar
Turn the boost down, and more seat time. I did not get to the race track enough last year. I have a track pack, just need to use it .
Old Jan 2, 2014 | 12:27 PM
hamburger_train's Avatar
Main goal is finding a beater to rid her of the daily abuse.
After that maybe exedy twin disc, front and rear sway bars, and maybe some good ceramic pads on all corners. Maybe cams too!
