Another noob question...
Old Jan 9, 2014 | 10:08 AM
OPENA(671)'s Avatar
Are a/f ratio gauge and wideband o2 gauges the same thing? Someone told me they're not. Aren't they used for the purpose? Got me confused.
Old Jan 9, 2014 | 10:25 AM
EVOjunky's Avatar
yes
Old Jan 9, 2014 | 11:23 AM
jrainwater's Avatar
I think what they were trying to say is that there is a difference between a basic a/f gauge that you can buy at pepboys. Those cheaper ones use a narrow band o2 sensor to operate off of and that is not accurate enough for tuning purposes. A wideband reads the whole spectrum of a/f ratio and uses a laboratory grade o2 sensor to read from. So technically yes there is a difference between a basic a/f gauge and a true wideband set up. If youre going to be using this for tuning you need a wideband.
Old Jan 9, 2014 | 12:15 PM
Bhsj13's Avatar
^^ Yes
Old Jan 9, 2014 | 02:20 PM
EvolutionIX219's Avatar
Go with the AEM wideband
Old Jan 9, 2014 | 04:32 PM
OPENA(671)'s Avatar
Thanks for the replies. I bought a autometer wideband already. But the guy got me second guessing myself. Thanks for the clarification.
Old Jan 9, 2014 | 06:53 PM
sadc's Avatar
If you like flashing lights that dont do anything. Get a narrowband. If you want a gauge for tuning your car then get a wideband. Which you already have
Old Jan 9, 2014 | 11:24 PM
Biggiesacks's Avatar
Another good idea would be to patch your ECU to eliminate the Rear, post cat, Narrow band 02 sensor and wire your wideband's analog output directly into the stock ECU. This will make logging much easier when using a program like Evoscan. Also if you use a TephraV7 rom you can set up a warning that will flash your CEL and or Cut boost if your AFR's go to lean (programmable) over a certain load (programmable). See ECUflash subforum for more details.
Old Jan 9, 2014 | 11:28 PM
OPENA(671)'s Avatar
Thanks for the idea. I am planning on tuning my car myself. Will give it a try when I get a chance to install my gauges.
Old Jan 9, 2014 | 11:33 PM
NP, the amount of tuning information/knowledge over in the ECUFLASH sub will blow your freakin mind. Your one stop shop for learning to tune your evo.
hussein
Feb 17, 2017 11:11 AM
roidz3
Oct 2, 2016 08:55 PM
Perplex
Dec 12, 2015 11:21 AM
kapolani
Jul 4, 2006 11:21 PM
ski10804life
19
Jan 13, 2005 08:35 AM
