Help-ID1000cc Injector Grommets(insulators)?
Old Feb 7, 2014 | 08:53 AM
CNC_OUTLAW's Avatar
I'm about to finish my 2.3l build on my Evo 8 and noticed that my ID1000cc injectors seem to be loose. I wanted to see what type of injector grommets (insulators) you guys are using to properly seat the ID1000's. I currently am using a 204 lower cushion ((o-ring) part # 92.1) that Injector Dynamics supplied me with after getting injectors cleaned.
Any advice would be appreciated!
Old Feb 7, 2014 | 03:19 PM
Grimgrak's Avatar
I could use some too but the ones on the intake manifold side.
Old Feb 7, 2014 | 03:45 PM
CNC_OUTLAW's Avatar
Those are the ones I'm taking about, going from the bottom of injector to intake manifold.
Old Feb 7, 2014 | 07:28 PM
egis's Avatar
personally i use stock insulators.
Old Feb 8, 2014 | 10:43 AM
CNC_OUTLAW's Avatar
Got ya, I will try that if I run into any issues. I'm thinking the lower o-rings (cushions) just need to heat up to seat properly.
Old Feb 8, 2014 | 12:19 PM
egis's Avatar
if you still on stock IM,stock insulators should sit snug,if they dry,cracked or hard and brittle,then you need to replace them brother.
Hiboost
Sep 30, 2015 05:05 AM
02modlanceroz
Jan 10, 2015 03:35 AM
CeeWhizzle
Mar 17, 2013 06:47 PM
riceball777
Mar 15, 2011 05:15 PM
RSMike
31
Dec 1, 2010 01:30 PM
