boost spike at 24~25p.s.i.
Old Mar 3, 2014 | 11:46 AM
mykep83's Avatar
My wives evo is spiking at 24/25 and settling down at 20/21 ?
she has injen i/c piping and intake, hks downpipe on a 3" exhaust w/o resonator. we did gauges too.
are these numbers normal? I would not think they are? I know I need to have it tuned and plan to have that done in a month or two but more curious.
thanks
Old Mar 3, 2014 | 11:54 AM
EatSleepBoost's Avatar
Alot of people have been seeing high boost recently. Have you been boosting in 4th or 5th gear on very cold days?
Old Mar 3, 2014 | 12:02 PM
mykep83's Avatar
it was a pretty cold day actually. they were 3/4 gear pulls
Old Mar 3, 2014 | 12:11 PM
Yea the temp could be part of the problem. Do you have a mbc on it? When was your last boost leak test. It is also possible the boost you are running is 25psi but since you have a leak bleeding off about 4psi you see 21. On initial spike of boost you could see that high number for a second then it starts to leak out.
Old Mar 3, 2014 | 07:47 PM
egis's Avatar
Op its all good no worries.you were tuned for around 23# right?
Old Jul 23, 2014 | 12:18 PM
pekpekbuster's Avatar
i'm having almost this exact same problem. i recently had my head off and reinstalled with new gaskets. my car was and has been tuned for about 20psi. my mechanic said that no adjustments were made to either my manual boost controller or my bypass valve (synapse). while driving it home from the shop, it was spiking at 30psi, and tapered down to around 25psi. no CEL came on though. since then (over the weekend) i've significantly adjusted the MBC almost all the way down, but it's still spiking at 25psi, then tapers off and holds at 20psi under full boost. anyone know what may be causing this??
Old Jul 23, 2014 | 01:55 PM
NeveReveN's Avatar
Sometimes aftermarket BOVs and manual boost controllers can do that, does your wife have either installed? Also like everyone else was saying it might have to do with how the car is runnning due to the weather.
draconx
Oct 23, 2014 03:03 PM
brenner
35
Aug 25, 2010 10:05 AM
2hot2handle
13
Jul 30, 2006 06:25 PM
statix
14
Mar 27, 2005 03:02 PM
GOKOU
11
Jun 9, 2004 06:20 PM
