Yet another what oil should I use thread
he says it helps with wear protection, but can't speak for any other aspect. too risky for me.
my regular oil does great as it is. i like the zinc content in it.
I agree 100% . Guess I was pointing out the obvious. Despite that I still run it. I used to run Motul and before that ENEOS.
I used to run that WAY back in the days when that stuff first came out and you had to order it over the mail-- yes the early days of the internet. I ran it in my C4 corvette at the time, stuff was ok I guess. Nothing magical happened so Im sure its just like duralube, Zmax, or similar stuff out there. Save your money.
I'm a fan of Brad Penn for turbocharged/gasoline applications. I run 20w50, but that all depends on your applicastion and climate.
Interesting sales model indeed. I always thought they were missing out by not utilizing the standard 3-step distribution process. But maybe I was wrong... By making everybody a dealer, everybody is now an unpaid salesman for the product. Free labor/advertising. Way to go Amsoil!
gsrboi's response is because it seems like Amsoil has alot of fanboys based on their sales model. Seems like everyone and their mother is a Amsoil dealer and they always quote stuff about their oil that sounds like its right out of a Amsoil press release/product knowledge sheet/propaganda.
He also mentioned the possibility of increased corrosion. Not worth it, imo.
This is the point I was making. In your example, I assume your needing to run a thicker oil due to bearing clearances, so a 10w60 works better for you than say, a 10w30. For someone, like me, that is still on the oem shortblock a 10w60 does not make sense. That's why there is no ONE best oil. Maybe that's why folks keep posting that question on online forums, they just don't understand there is no one best for everything, just the better option for your needs/setup.
I have never tried Liqui Moly, but I have to assume it is a good oil as per our literature Mercedes Benz approves their 60 weght lineup for their AMG, SLS, and SLR cars.
IMHO, if your not running a built motor any good synthetic 5-20 - 10-30 is fine
if your running a built motor you run brad penn.
but you cant run brad penn if your still under warranty you will void it, its not a full synthetic its a blend: FYI
Stock motors I've used 10-30 amsoil in and they work great. High hp stock motors I use 10-40 with a lot of zinc. Built motors, IMO anything over .0023-.0022 clearances need a heavier oil with a good amount of zinc.
Nice to see that you at least explained why you chose it instead of other posts just stating it with no supporting data as to why.
Ever wonder if its that great of an oil why would it void a warranty? What possible circumstance could that oil ever do that Mitsu might need to do an UOA on it... just throwing that out there.
so.. i'm sure it's been asked and i apoligize in advance, but what is the drawback to running an oil that is a bit too thick? i ask because i am building my engine soon.
In a warm climate and in a performance application, there really is no measureable drawback to running thicker oil. Just keep it within reason...
my weather here is a low of about 35-40 in the winter and high of 108* or so in the summer.
