random question
Old Mar 25, 2014 | 09:36 AM
hiner005's Avatar
random question
Can you run an oil feed line from the oil filter housing to the the turbo on an OEM 8 or 9 turbo? If not, what is the thread pitch on that housing so I can plug it if I go back to my OEM turbo?
Old Mar 25, 2014 | 09:39 AM
bbong's Avatar
I think you can but you need a proper restrictor pill otherwise you may damage the turbo.
Old Mar 25, 2014 | 09:40 AM
rjfg's Avatar
Is there going to be an issue with the fact the filter sits lower then the turbo though;
Old Mar 25, 2014 | 09:43 AM
llauer76's Avatar
On dsm's a lot of people run the feed from the OFH, so evos should be no different. I do believe the above is correct though. You'll need a restrictor.
Old Mar 25, 2014 | 09:45 AM
llauer76's Avatar
And the fact that it sits lower than the turbo shouldn't matter as long as you have oil pressure. It's not gravity fed.
honda-guy
28
Jan 30, 2021 08:48 PM
real fast
Apr 15, 2016 05:28 PM
real fast
Feb 9, 2016 06:59 PM
CN9Adaiski
Jul 5, 2014 02:02 PM
RSGuy
Mar 7, 2014 06:43 PM
