Leaking fuel at FPR?
Old Mar 31, 2014 | 07:49 PM
black_beauty's Avatar
My FPR is leaking fuel at the return on the bottom and I don't know why. I have a Buschur Double Pumper, 1450 injectors on e85. Any help is appreciated...
Old Mar 31, 2014 | 07:53 PM
TommiM's Avatar
Are you talking about the oem fpr on the fuel rail? It likely just failed internaly, it happens. Its going to need to be replaced obviously.
Old Mar 31, 2014 | 08:13 PM
Yes oem on the rail.... I was told to pull the vac hose and if it was bad it would leak fuel and it did not...
Old Mar 31, 2014 | 08:19 PM
superbovine's Avatar
That's only one way it can fail; it not doing that doesn't make it ok.
Old Mar 31, 2014 | 08:28 PM
Ok, vest place to source a new one?
Old Apr 1, 2014 | 01:39 AM
evotuner04's Avatar
15 Year MemberLikedLoved
go to maperformance.com and buy a new one, it'll be at your door in about two days
Old Apr 1, 2014 | 07:42 AM
do they have stock, im not too interested in an adjustable one...
Old Apr 1, 2014 | 07:51 AM
Evo_AK's Avatar
Veteran: Air Force
Here ya go.
oemmitsubishiparts.com/parts/2003/Mitsubishi/Lancer/Evolution?siteid=214331&vehicleid=140001&section=F UEL%20SYSTEM&group=FUEL%20INDUCTION&subgroup=FUEL% 20INJECTION&component=FUEL%20PRESSURE%20REGULATOR
Old Apr 1, 2014 | 08:34 AM
Thanks, have one ordered im pretty sure this should fix my problem...
Old Apr 7, 2014 | 02:29 PM
new FPR DID NOT solve my problem, still leaking at the return and running lean. Getting very tired of buying parts I apparently don't need. What do I check next? VERY FRUSTRATED, any ideas are appreciated. Thanks.
Old Apr 7, 2014 | 03:24 PM
jrainwater's Avatar
Are you running a fuel pump full voltage rewire kit?
Old Apr 8, 2014 | 07:30 AM
no, and the second pump is activating around 5psi
Old Apr 8, 2014 | 12:37 PM
jrainwater's Avatar
I was just thinking that the stock fpr would have issues handling a double pumper but I looked and I guess a lot of ppl set up that way. I have a 340 single on a rewire and it was over running the stock fpr tho.
Old Apr 8, 2014 | 06:15 PM
at idle and cruise its one pump so it shouldnt be able to overrun the stock FPR. I got the leak fixed I guess it was just a crappy clamp, I bought a 1/4" fuel hose clamp and put it on.
Old Apr 8, 2014 | 06:47 PM
jrainwater's Avatar
Sweet, I love when it ends up being something ez
