need help
Old May 6, 2014 | 01:33 PM
tbaird58's Avatar
need help
hey guys i was getting tuned yesterday and my tuner said he had good news and bad news. good news was that my turbo isnt stock and he thinks its an early fp green or 20g turbo, but the bad news is that my car will not make any power over 270 and seems to fall on its face after 5k rpm. i have basic bolt ons and should be seeing 310 or more now that we know the turbo isnt stock. we did a boost leak test and i have no leaks up to 25psi, checked compression and that was 160/160/170/170 so that was fine and my spark plugs and wire check out. does anyone have any ideas what could be causing me to lose so much power? any help would be great. my tuner and i are stumped right now
Old May 6, 2014 | 01:41 PM
jrainwater's Avatar
Fuel cut above 5k???
Old May 6, 2014 | 02:00 PM
tbaird58's Avatar
the air to fuel ratio was steady all the way up to redline no drop offs
Old May 6, 2014 | 02:02 PM
jrainwater's Avatar
Wga holding good too?
Old May 6, 2014 | 02:11 PM
tbaird58's Avatar
yeah as far as i could tell, im sure my tuner would have caught that on the logs but he didnt see any irregularities
Old May 6, 2014 | 03:02 PM
tbaird58's Avatar
anyone else have any input?
Old May 6, 2014 | 04:05 PM
tbaird58's Avatar
talked with my tuner, fuel cut doesnt start til after redline and im holding boost throughout the rev range so the wastegate is doing its job. still stumped
Old May 6, 2014 | 07:08 PM
BULLETEVO's Avatar
Might be a collapsed cat in the exhaust causing a massive flow restriction.
Old May 6, 2014 | 07:56 PM
tbaird58's Avatar
i have full catless turboback :\
Old May 6, 2014 | 08:16 PM
VanduzerWilliam's Avatar
maybe a kitty cat crawled in there and is stuck :X
Old May 6, 2014 | 09:09 PM
tbaird58's Avatar
that would suck haha but i dont think its blocked since i just had the exhaust off a couple weeks ago replacing the gaskets to the test pipe
Old May 7, 2014 | 09:06 AM
Thore's Avatar
After 6k rpms the old fp green will just be blowing hot air.
Have you checked the TPS?
Old May 7, 2014 | 09:26 AM
adamsheehy's Avatar
Are you able to do any pulls and post some logs?
Old May 7, 2014 | 09:34 AM
cmspaz's Avatar
Logs, graphs, anything you can post?
Old May 7, 2014 | 01:57 PM
tbaird58's Avatar
I'll talk to my tuner and see if I get the charts from him or see if he will post it here
