Engine rattle (rocker cover)
Old May 17, 2014 | 12:49 PM
Danny_lad's Avatar
I've had the car 4 weeks and seems I've got a rattle coming from under the rocker cover!
Tends to appear around 1500rpm and go around 2krpm it doesn't increase with revs either and it's so annoying?
I've got a video!
You can hear it after I rev it!
Old May 18, 2014 | 09:48 AM
Danny_lad's Avatar
Anyone
Old May 19, 2014 | 07:51 PM
X Double Dot's Avatar
Any chance it's the wastegate flapper arm rattling or is it for sure under the valve cover?
Old May 21, 2014 | 01:54 PM
Danny_lad's Avatar
Yeah if am driving off throttle it rattle ! But if I slightly put my foot down it goes!
If I build boost it's gone, so am thinking it's that too! If it is? Easy to sort out?
Old May 22, 2014 | 11:26 AM
While I haven't had to do it myself, adjusting the preload is fairly simple as long as u can reach the rod. Worst case would require removing the radiator on the Evo. Just Google "how to set wastegate preload" in YouTube. Typically I think you adjust it so half the pin on the wastegate arm covers the hole in the adjuster rod.
GGevoX_915
Aug 24, 2018 06:38 AM
Babs
Oct 7, 2015 04:05 AM
theonlyherb
Dec 28, 2014 03:45 PM
dxlykos0131
Dec 8, 2013 07:59 PM
boobcakes
Evo X How Tos / Installations
55
Dec 19, 2011 10:05 PM
