Evo that has been sitting for a year
Old Jun 30, 2014 | 05:06 AM
xxevo8xx's Avatar
Currently wanna know whats the value for an Evo 8 that's been sitting for a year. It has problems, and needs maintenance work. I understand they won't be releasing anymore Evos after 2015 so maybe that could add value to them down the line?
Old Jun 30, 2014 | 05:09 AM
oscarquinones's Avatar
what year and how many miles it has. And also when you say problems what kind
Old Jun 30, 2014 | 03:55 PM
19DB794's Avatar
Ontop of knowing miles and the work needed, was this car stored inside or outside?
Old Jun 30, 2014 | 06:31 PM
xxevo8xx's Avatar
2003 with about 115k miles. It was stored outside. It starts up but the stock intake manifolds heat up. I think it needs a new radiator and wondering maybe if that could be the reason why it heats up.
Old Jun 30, 2014 | 08:25 PM
Igaly1021's Avatar
for a 30-04 with 115K needs maint. done i wouldn't pay more than 10-11k
Old Jul 1, 2014 | 05:14 AM
xxevo8xx's Avatar
I appreciate the response, thanks man.
Old Jul 1, 2014 | 05:53 AM
NSDQ's Avatar
2003+115k miles+stored outside for a year+needs some level of work=not taken care of IMO. I'd pass on it unless you have disposable income and can get it for a bargain or you can take on a project. Really the miles wouldn't scare me, but with it left outside, that does. And you say you're East Coast, so depending where, like northern East Coast, probably seen some salt from the winter previous to sitting. Any rust on it?
Old Jul 1, 2014 | 06:52 AM
xxevo8xx's Avatar
Not on the outside on the body, but some on certain parts inside the motor. The problems are as follows. -May need a new headgasket. -Needs a new radiator. -Needs all oils to be flushed. -Needs a new tune. -Needs a wheel alignment. -Needs new brake and ebrake pads. -Idles very low.
Old Jul 1, 2014 | 06:54 AM
xxevo8xx's Avatar
If possible, how much do you think on the average it would cost to fix all these problems?
Old Jul 1, 2014 | 07:45 AM
19DB794's Avatar
I would say doing the work yourself your looking at ~$2500. That's being on the safe side incase something else comes up and you might as well replace the timing belt, water pump and balance shaft belt too. How come it needs a new head gasket? Is anything warped?
Old Jul 2, 2014 | 02:53 AM
xxevo8xx's Avatar
I haven't checked, and honestly I'm inexperienced with automotive repairs. I will have to send it to a professional for further inspection but thanks, I appreciate all the help so that I could at least have an idea what kind of problems the car has.
Old Jul 2, 2014 | 03:35 AM
19DB794's Avatar
Your probably going to need a new set of tires as well since the flat spots might cause vibrations that won't go away.
Old Jul 2, 2014 | 08:37 AM
EvoTillIDie's Avatar
I'd definitely buy this off of you for the suggested price
Old Jul 3, 2014 | 04:39 AM
xxevo8xx's Avatar
If I were to sell the car I'd probably look into selling it for less than 10k with all the problems.
Old Jul 3, 2014 | 07:07 AM
xxevo8xx's Avatar
It's a pearl white evo, there are purple tints when the sun shines on it but its hard to tell in the picture. I'm just debating whether or not I should fix it up and keep or sell it as is with a reasonable price.
Attached Thumbnails Evo that has been sitting for a year-20140519_153137.jpg
