Needing help evo 4
Old Jul 12, 2014 | 04:39 PM
Dunkernick's Avatar
Needing help evo 4
Hi all this is my first evo after owning an impreza for a number of years and having trouble all ready.
I have a evo 4 jap import 96
Has a 3" stainless system from japan.
Air filter fitted with cold air feed
And a greddy profec B spec ll
Don't know what els has been done.
When I had it I looked through the boost controler at the peek it had been used which was 21 psi.
But I have been running at 14 psi and well it's no good.
10 psi 3rd gear WOT runs perfect.
11.5 psi 3rd gear WOT from 4000rpm it's stuttering misfiring and poping a little and well try to do 14 psi and you don't go anywhere fast.
The best peek I have has is 11 psi.
I have checked for air leaks, turbo pipes, coils, and all wires and can't find anything out of place.
I had a play with an focus st and lost this is how low I'm having to run it.
Also from cold to start it I have to use a tiny bit of throttle as it won't start otherwise after 40 secs it's ok but does hunt a tiny bit now and then. It has had the idal control valve changed but no change.
Any help welcome and anyone near Dudley welcome to look as I am really stuck now.
bbong
Jun 11, 2017 05:25 AM
Dunkernick
Jul 24, 2014 07:17 AM
Anubis18
May 9, 2013 07:17 PM
David Buschur
114
Feb 4, 2013 09:02 AM
domyz
Oct 19, 2012 06:34 AM
