couple of questions
Old Jul 12, 2014 | 10:16 PM
LSXevo's Avatar
couple of questions
ok so ive been on looking at some peoples hp numbers and i look at mine and it seems really low for what psi it is tunned at
specs-- (from what i can see and know from paper work)
everything was put on by boostin performance and it was tunned by them aswell
3" tubro xs downpipe and mid pipe
grimspeed ebc at 25psi
walbro 255
tial qr bov
injen intake and injen hard intercooler piping
tubular exhaust manifold
car was boost leak tested and injector orings were replaced and so was the throttle body seals
car made 285awhp on their dyno with 93 pump gas
does this seem right? from some of the numbers im seeing on here this seems a little low for what it has done to it i know its not that much but still from what i have read like 250 is stock hp numbers
thanks,
Cory
Old Jul 13, 2014 | 08:11 AM
Raptord's Avatar
What kind of dyno?
Old Jul 13, 2014 | 08:55 AM
hiner005's Avatar
What turbo should be more like it....I only made 295 on my stock Evo 8 turbo with an intake and a MBC everything else was stock...all piping etc. could be their low reading mustang dyno. You could have a stock 8 turbo with the 9.8 hotside as well. So many factors go into a tune. Just call or email them and ask them why it is so "low" compared to what you want and go from there
Old Jul 13, 2014 | 09:22 AM
oscarquinones's Avatar
yeah that is to low. You should be around 310 to 330
Old Jul 13, 2014 | 10:23 AM
LSXevo's Avatar
i belive it is a stock turbo not sure what hot side would the stamping on the housing tell me?
Originally Posted by Raptord
What kind of dyno?
its a mustang dyno
Old Jul 13, 2014 | 10:28 AM
Raptord's Avatar
Originally Posted by LSXevo
its a mustang dyno
That's why your numbers are lower compared to others you've seen here. Most people here have dynojet numbers, which read higher than mustang dynos.
hiner005's Avatar
Yeah plus you're on stock injectors as well according to your post so I see nothing that wrong with you numbers besides it's at 25psi for boost which seems like a lot for a stock 8 turbo and stock injectors
Old Jul 13, 2014 | 10:45 AM
you need good injectors, o2 housing it will help that exhaust. And with no offence I don't trust injen intake and intercooler piping as much ETS and AMS.
Old Jul 13, 2014 | 11:46 AM
Bhsj13's Avatar
looks fine on a mustang dyno.
Old Jul 13, 2014 | 05:23 PM
Nohatn's Avatar
mustang dynos rob your numbers but from your spec you listed. you need injectors your stocks should be raised up. I would say anything over a 1000 for E85 (even if dont have you might get later and incase you want more power down)
Mustang dyno vs Dynojet think its 12-15% difference
so your prob 320 to 340 to wheels..
Do the e85 and injectors turn that boost up wouldnt be shocked close to 400hp
Old Jul 13, 2014 | 09:49 PM
LSXevo's Avatar
thanks everyone for the info i apreciate it but for right now its just my dd dont really want to start modifying it more than it is (even though its not that much done)
one more question ive seen a couple of threads that people are saying that the transmissions arnt that good is that for just a certain model or for all of the evos?
Old Jul 14, 2014 | 05:04 AM
slow gst's Avatar
The 6 speeds that come in the MR are considered to be weak compared to the 5 speed.
Old Jul 14, 2014 | 10:52 AM
Bhsj13's Avatar
i would say it is fine until you start hitting higher than 350 wtq.
Old Jul 14, 2014 | 11:53 AM
LSXevo's Avatar
ok thanks i have the 5spd i was just kind of worried about it
OwensT4211
Feb 17, 2015 08:45 PM
her name is eva
Sep 2, 2013 06:36 PM
boostedmkiii
Apr 20, 2013 07:20 PM
@MR EVO@
Oct 14, 2009 12:28 PM
4TUN8
15
Mar 14, 2007 10:12 AM
