New Owner Getting familiar with engine
For those who says it's ok to leave it unplugged and hanging are not too familiar on the importance of a good Pcv system and how important it is. OP, either have it go to catch can and then to intake or some sort of vacuum source or plug it into intake tube. That breather during negative vacuum (off boost) sucks in metered (very important it's after Maf so it's accounted for by Ecu) from intake tube and Pcv valve on other side of valve cover sucks out positive crankcase pressure via intake manifold. During positive pressure (boost), the Pcv valve utilizes it's built in check valve and stops sucking air to manifold and that breather line needs some sort of vacuum to suck crankcase pressure out (intake tube) If not, crankcase pressure can blow rings, seals etc. hence the importance of a good working Pcv system.
Some good info can be found here: http://www.dsmtuners.com/threads/the...system.366890/
The two that i hear people have problems with are Weapon R & Cusco.
Weapon R - does not bolt in easily with the strut brace. (it actually designed to sit in the frame of the strut)
Cusco - designed for JDM vehicles (LH drive) may not bolt in easily.
but both are possible if you are determined.
Ive not heard about the other brands.
majority of catch cans i see are around the 100 - 150$ mark.
Ok, that's much better, the one I saw was like 250+, I'll definitely put it on my list of upgrades. Thanks for the info
