Need help installing GReddy Profec B Spec Boost Controller
Old Aug 28, 2014 | 08:33 PM
zboost's Avatar
I'm wanting to install my GReddy Profec B Spec Boost controller but need some help. Currently running a 44mm TiAL External Wastegate @ 22PSI & a SARD Fuel Pressure Regulator
I have wired the controller up, it's powering as it should, I just need to hookup the hoses.
Need help with the following:
> Behind the boost controller is a port (Pressure Inlet) which a hose is attached to, then a Air filter, then another hose at the other end of the air filter, this is then supposed to be connected using a 3 way joint between the fuel regulator and the intake manifold.
*Where abouts should I tap into? The hose going from the top of the fuel regulator to the intake manifold has already been tapped into for my boost gauge.
The boost controllers motor box has a OUT and IN port round the back
> The OUT port is supposed to have a hose going from the motor box to the external wastegate.
*My wastegates port already has a hose going down to the turbo, do I just tap into this hose or is there another way to connect to the wastegate?
> The IN port is supposed to have a hose going from the motor box to the intake manifold.
*The port on my intake manifold is already used up going to the blow off valve, do I just tap into this hose?
The instructions are at the following link - http://www.greddy.com/upload/file/PRofec_Bspec.pdf
Old Aug 29, 2014 | 04:09 PM
zboost's Avatar
bump
stamatis evo6
Aug 3, 2015 10:02 AM
TeStUdO
For Sale - Cars For Sale
35
Sep 26, 2014 08:55 PM
The442GTO
12
Sep 23, 2014 01:18 AM
lghtngyello03
Jul 14, 2014 09:54 AM
