My Evo 9 Misfiring. sounding like it has cams.
My Evo 9 with 61k will take awhile to start it will crank for a long time then will start but if I leave the car on the "ON" postion for like 2 min it will fire right up. Car sound like it has cams but doesn't. What can it be?
Fuel pump?
Injectors?
Crank angle sensors?
Coil pack?
Fuel pump?
Injectors?
Coil pack?
Sounds like a Suby? Have you done the Timing Belt job since you are at 61K?
Check your timing and make sure you belt did not jumped a tooth or two...throwing your timing off and sounding like a Suby...
Throw any codes? Check vacuum lines? Boost Leak?
timming good no codes lines are good
