Video: Car cranks, has fuel, spark, but does not start.
Old Sep 14, 2014 | 12:29 PM
bnr34rb26dett's Avatar
Exclamation Video: Car cranks, has fuel, spark, but does not start.
Title pretty much explains my situation.
Evo cranks, has fuel, spark, all fuses checked.
However, it sometimes does not start up.
Battery is healthy and car gets full electricity when key is in ignition.
UPDATE
1. Car cranks but stops after cranking a few times
2. Car starts up after sitting for an hr or so sometimes. No issues with driveability once the car starts. However, it still does not start sometimes after sitting for a while.
It sounds like the starter is spinning freely without latching onto crank. This makes me think that it may be the starter.... If there is a relay that i should check let me know before i go out and test out a new starter.
Here is a quick video of the "start"
Old Sep 14, 2014 | 12:54 PM
Bhsj13's Avatar
whats with the bang, bang sound?
Old Sep 14, 2014 | 04:25 PM
llDemonll's Avatar
check the ignition fuse, fuse #1 under the kick panel i believe
edit: after watching video doesnt seem like that. how do you know battery is good?. cranks VERY slow for being a good battery
Old Sep 14, 2014 | 04:30 PM
aggieEVO's Avatar
Check all your fuses. Check to see if you can talk to the car with evoscan. I had a MAF wire short out against something and take out my ECU fuse. Did you just get the car back together? How's your timing?
Old Sep 14, 2014 | 04:31 PM
Boltz.'s Avatar
FCOTM Winner
Sounds like your starter is bad.
You can hear it spinning but it isn't spinning the motor.
Old Sep 14, 2014 | 07:24 PM
Yep, i have checked all my fuses. i know of #1 to go bad but its not that this time. Battery is healthy as well.
Fuse has been checked all around. Evoscan may not be a bad idea but theres no CEL and everything is well. Car did just got put together and timing is good and it was running good for a few hundred miles already
not sure. but it only did that once i dont think its an issue...
exactly. starter seems to be spinning freely without latching onto crank.
Whats confusing
2. Car starts up after sitting for an hr or so sometimes. No issues with driveability once the car starts. However, it still does not start sometimes after sitting for a while. This makes me think that it may be the starter....
Old Sep 14, 2014 | 07:28 PM
EatSleepBoost's Avatar
Your car does not crank. Starter or starter connections.
Old Sep 14, 2014 | 07:49 PM
i was thinking that too now that car started but inconsistent.
Old Sep 14, 2014 | 08:02 PM
galantman03's Avatar
use a hammer and GENTLY tap on the stater solenoid, and see if that changes anything. Also when you crank the key, meter and see if indeed you are getting 12VDC to the solenoid. Also, check grounds just to be sure.
Old Sep 14, 2014 | 08:13 PM
Thanks for the input.
Ground was actually bad at the trunk relocation before this issues started. i fixed the problem and realized car was no longer starting.
Old Sep 14, 2014 | 08:23 PM
No prob man, Other thing that popped into my head was the ignition switch. The only reason why I mention it is because that was my problem, it was charred and burn where it should have made contact. But mine was more of a chattering starter solenoid. anyway, good luck!
Old Sep 14, 2014 | 08:47 PM
Bhsj13's Avatar
maybe a loose starter bolt? or, that little black wire to the starter?
Old Sep 15, 2014 | 07:12 AM
illusin's Avatar
Random question but do you have a aftermarket alarm system ? if you do did you disable it
Old Sep 15, 2014 | 07:52 AM
Boltz.'s Avatar
FCOTM Winner
Just go buy a new starter. It is likely the overrun clutch that has gone out.
Old Sep 15, 2014 | 06:08 PM
So I went under the car and it seemed that starter solenoid has come loose!
Got a new starter and problem solved!
Thanks to all of those who helped me out
